Again great and very interesting reading. I will tuck this away in my brain cell for future reference for when (if!) I ever get this project to the top of the list.
Many thanks!
How to test a battery cable?
- Has thanked: 2210 times
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
My layman's summary:
Keep adding amps until it starts to smoke. Write that number down, that's too much.
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I replaced mine a few years ago, I'm trying to recall what led me to conclude it was necessary.
- Low charging voltage at the battery. Alternator connects to starter, which connects to battery, iirc. Just a little voltage loss, but
- Visible corrosion on the wire immediately adjacent to the battery clamp
For identifying a good or bad cable in a salvage yard, I'd probably look for that corrosion in the wire. That's really most of what can go wrong with it, (other than major damage that's readily visible.)
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
Like I said, the battery end is covered by a molded rubber boot a bit like thick heatshrink. You would have to cut that off to see the top end.
The other end is likely to have more corrosion as it sits at the back of the starter motor and is closer to the ground, so splashing water is more likely to affect the bare ends of the wire strands at the starter clamp.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I remember reading somewhere that one of the contributors to the failure of the crimp connection at the positive battery post is fumes rising from the sulfuric acid electrolyte inside the battery cells reacting with the copper metal in the cable causing corrosion.
I guess it depends on how good the seal is on the +ve battery terminal is. It seems to be good.
That brings about another good point. Batteries used to (and I believe I have seen recently) have a vent hole for off gassing. There is supposed to be a drain pipe for that taking the fumes away from the battery area. When did you last see one of those?? Can you even buy them any longer?
- Has thanked: 987 times
- Been thanked: 1078 times
If you are asking have I seen the battery vent tubes, Yes, I have them on the V70, my 2001 Mercedes, and the 2009 Smart, Just a rubber/plastic tube through a grommet to under the car.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,scot850 wrote: 22 Feb 2024, 10:21 I guess it depends on how good the seal is on the +ve battery terminal is. It seems to be good.
Oh, I don't remember seeing those I must have forgotten them (the hoses).
I do remember seeing one of the battery platforms where the battery sits corroded.
- 11 Replies
- 4507 Views
Last post by gusinfantino
- 1012 Views
- 2752 Views
- 1269 Views
- 1838 Views
Last post by lcc014
