Vida CEM swapping
Skavac
- Year and Model: 1998 Volvo S90
- Has thanked: 2 times
- Been thanked: 6 times
Not trying to threadjack, a lot of people here are experts on Volvo modules, and maybe can help me with this.
We know key information is in CEM, and we can program new key by reading 28F400 or 93C86 and adding key ID to dump, and write crypt key to the transponder. However the remote is a bit more challenging.
A remote for P2 Volvos come with 2 codes, the short code and the long code.
In the first remote
Short: 0D7D101F
Long: 0A1C 2366 63D9 816D
In UEM Eeprom, short code goes to address
0x0C to 0x0F
However, the long code is changed from
0A1C 2366 63D9 816D to 2070 68DD 100D 1014
This code goes to address 0x4C to 0x53
Another remote
Short: 0084B4EA
Long: 0980 E5AC 2BDB 57E7
Short code is unchanged
Long code in UEM: CE78 E54B A06B 622E
I would like to know how to translate long code from the key's seed to the UEM code so the remote can work.
In the first remote
Short: 0D7D101F
0x0C to 0x0F
Another remote
Short: 0084B4EA
Dudde
- Year and Model: 2005 V70 and more
- Has thanked: 17 times
- Been thanked: 17 times
Can you upload dump so i can take a look. I myself have wondered the same.Skavac wrote: 28 Feb 2024, 16:23 A remote for P2 Volvos come with 2 codes, the short code and the long code.
In the first remote
Short: 0D7D101F
0x0C to 0x0F
Another remote
Short: 0084B4EA
Skavac
Dudde wrote: 28 Feb 2024, 23:06Can you upload dump so i can take a look. I myself have wondered the same.Skavac wrote: 28 Feb 2024, 16:23 A remote for P2 Volvos come with 2 codes, the short code and the long code.
In the first remote
Short: 0D7D101F
0x0C to 0x0F
Another remote
Short: 0084B4EA
Attached are 3 files in this zip. One original file, another for the first remote, another for the second remote
- UEM Dumps.zip
- (1.36 KiB) Downloaded 138 times
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
You need go another way if you want add used remote in UEM.
This way only good if you get UEM + remotes as you already noticed SEED Key is rolling one.
You need program they remote itself if want make it as a new specially when UEM is missing or sniff it all via radio.
Edit: for some reason its working again now, i got this pin 54 00 49 92 74 13.
Is this the actual pin or does it need to be converted into something?
Skavac
Can you tell me more? You can program the remote if UEM is missing? Can the long UEM code be sniffed from radio?xanthefin wrote: 29 Feb 2024, 03:24 You need go another way if you want add used remote in UEM.
- 9380 Views
Last post by RickHaleParker
- 9398 Views
- 27 Replies
- 29076 Views
Last post by cn90
- 10 Replies
- 10919 Views
Last post by jonesg
- 6032 Views
