Has thanked: 1850 times
Been thanked: 1712 times
I should add that used to be on 4 different cars! Really sad I know, but it was also sad how many times I found items like thin wire, large construction staples, screws and nails in tires over the years. Fortunately, I now only need to one set of tires as the R is put away for winter on a set of 'slave tires/rims and the Toyota runs on mud/snow tires year round. Only the XC sees tire wheel swaps now.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
I wanted to test my low fuel light, and it works, but now I'm kind of circled back to one of the first problems I identified:
I can't tell if the top of my fuel float is off or if gas pump auto stop cuts off early.
Needle was on the red, low fuel light was on, just under 62L loaded. Gauge showed me right around where low 60s would be.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
Sigh, killed a deer (I assume) with the S70. Blew the passenger side window out. Destroyed my new headlight and turn signal, dented the door, and severely buckled the hood. Vibrates a little more, too, but the wheel didn't look damaged. Maybe turbulence, as I continued driving home at highway speeds. On top of that I just filled the gas tank today, so now I have to figure out how to hopefully pump that out.
Expect a sale post. I was planning on replacing it anyway. I guess I'm going to have to drive the 850 tomorrow even though there's still some salt out there.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1505 times
Been thanked: 3818 times
I’ve still got 98 and 99 body parts upstate? If it’s bolt on/off stuff just fix it, BuckRogers!
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
The Slime didn’t fully work, so I ended up having to plug a couple of the holes. It would’ve looked like a porcupine if I’d plugged all the holes. Let’s hope it holds!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
454cid
Post by 454cid »
abscate wrote: 01 Mar 2024, 01:30 I’ve still got 98 and 99 body parts upstate? If it’s bolt on/off stuff just fix it, BuckRogers!
I'm not sure what it would take. The car was in an accident before I got it, and the front end was already a little munched. Now it's much worse. I've thoroughly enjoyed driving the car, but I don't have the time and space to work on it. I'm gone 12 hours a day for work, and it's looking to become even longer. It would be a good rust free parts car for someone, Though, or I suppose it could be fixed. It hasn't even hit 120K miles yet.
Today, I found deer hair in the tire bead, which surprised me.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Bummer.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
454cid wrote: 01 Mar 2024, 12:18
You're gonna be finding deer hair everywhere. When I hit a deer in my X5 last year, I was noticing it on the door molding several weeks later when I finally decided to try to push out the dent it left in my passenger door.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
My s/v70 door card replacement inserts came from redlinegoods, so I'll be installing them sometime soon. We'll see how it goes, I don't see much about them online.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
BlackBart wrote: 01 Mar 2024, 14:19Bummer.
Especially for the deer...
1999 V70 GLT
