One of my cylinder head cover bolts is stripped and is leaking oil
1 I could pull the cover, retap, reseal
2 Im thinking I can do a Helicoil on car to fix
ANyone have experience here?
Flange screw
Part Number: 985135
Supersession(s): 975883
102338 Sjandix part
M7 x 35 mm flange bolt
P80 Valve cover bolt Helicoil , oil leak 985135
- WillieBeamen
- Year and Model: 1998
- Has thanked: 2 times
I use timeserts. I feel like more of a professional repair, but helicoil is an FAA approved repair as well.
McMaster Carr has the correct M7 x 1.o mm pitch Helicoil
https://www.mcmaster.com/products/helic ... c+helicoil
But it is listed as a through hole tap, and the cam cover is blind...
- Has thanked: 311 times
- Been thanked: 817 times
I had this issue on my 98, with one leaking cam cover bolt. It's just one of many and just the cam cover: I decided it is not worth the effort of a helicoil etc: I just tapped it larger on-car, carefully collecting the swarf as I did, and stepped up the bolt. Did not try to reseal or anything. No down time, no more leak.
Probably used a shorter bolt on the replacement so as to not tap too deeply, I could pull it and check length if you want.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I had to look them up to remember the difference. This is informative. The idea of a piece of Helicoil falling into a spark plug hole is a huge difference.
Thanks Eric. I can pull it , measure it, and document it hereerikv11 wrote: 05 Mar 2024, 10:37 I had this issue on my 98, with one leaking cam cover bolt. It's just one of many and just the cam cover: I decided it is not worth the effort of a helicoil etc: I just tapped it larger on-car, carefully collecting the swarf as I did, and stepped up the bolt. Did not try to reseal or anything. No down time, no more leak.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Another source that I mentioned earlier today:
https://www.mscdirect.com/browse/tn?sea ... words&rd=k
Getting any thread repair insert into a blind hole clean will be a challenge. There have been places I have done the one size bigger trick as well.
While this is the same, but different, we had a piston come apart in one cylinder on the stock car, with a big race the next day, so didn't have the time to do the right thing. An Ancient Machinist with an equally ancient portable boring machine came to the shop, bored that one hole 60 over in situ, we put it back together and went to the speedway. Engine didn't seem to care - aside from a bit more vibration over 8,000 .
Hey Foggy - a little bird told me you have a cylinder head currently off a car. Could you measure or SWAG the thickness of the head for me at tthe point where the M7 cover bolts go? I will post the exact one to measure here
Im leaning to drill and tap an M8
Three steps
Clearance for an M8 tap
Tap threads
Clearance cam cover for M8 through bolt
Three steps
Tap threads
- Has thanked: 987 times
- Been thanked: 1075 times
Here is some general information on tap types and tapping threads. Go slow and easy. Key point on blind holes is to get the cuttings out the top by frequently backing out the tap and cleaning. Good luck.
https://www.cnccookbook.com/different-t ... -choosing/
- BlackBart
Can you put a tiny nozzle on a shop vac and suck any shavings out of there?
- 11 Replies
- 19452 Views
Last post by volvolugnut
- 1246 Views
- 1587 Views
Last post by jeffsws
- 12 Replies
- 3719 Views
Last post by JimBee
- 20 Replies
- 4783 Views
Last post by ZionXIX
