Caide that is pretty incredible best ive seen on one of these units, how did you identify where to solder those connection onto the PCB?
I am trying out the Yatour unit right now but I am incredibly disappointed, audio quality sounds compressed and lacks midrange, so it seems the search continues.
Revisting AUX Input modification
That’s some nice wiring work.
I have a couple of good FM BT units that don’t buzz, I’ll put brands up today
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Bro. Gonna need a write up for this.Caide wrote: 13 Feb 2024, 01:24 I wired a bluetooth receiver straight onto the tape inputs on the PCB, it has inputs for next/previous track which I had to cut traces on the front panel inputs to get working. The receiver has separate audio and data grounds so no buzzing/noise
Randomnamegenerator
- Year and Model: 1996,850 AWD
Is there any advantage to using the CD port rather than using the hijacking the Tapedeck inputs like so many have done for the aux input mod?
I currently have a 12v Bluetooth module soldered to Tapedeck inputs and I'm looking into options for when I get the SC-901 running
coop
- Year and Model: 1998 s70 t5
- Has thanked: 17 times
- Been thanked: 15 times
I bought a cheap (like $40) standalone CarPlay adapter thing that had a fm modulator and aux output. It worked ok for a while both fm and with the tape adapter but I found a good deal on a blitzsafe Bluetooth/cd changer adapter that works great.
I’ve upgraded a majority of the stereo with other “stock” Volvo parts. Upgraded some speakers out of an s60r with slight modification and pulled an amp from a c70. But amazing sounding “stock” system
Randomnamegenerator
I haven't heard of this one beforecoop wrote: 03 Nov 2024, 06:46 I’ve upgraded a majority of the stereo with other “stock” Volvo parts. Upgraded some speakers out of an s60r with slight modification and pulled an amp from a c70. But amazing sounding “stock” system
Would you happen to know the part number for this?
Their website is not great and the one parts list I found only lists the Volvo aux products
coop
https://www.ebay.com/itm/125391555133?c ... U_EALw_wcB
9472753 Rh front.
3533967 Lh front
Are from some of the housings I’ve got laying around.
Best bet is too pull them at a junkyard and pay $10-20 for a whole speaker then buying them on eBay.
The rears pretty much bolt right up except they have an additional tweeter that gets slightly in the way when putting the rear deck back on so that needs to be modified. Or you can take the 8” out of the front from the above part numbers for the rear deck. I then took those 4”? Speakers and were able to get them into the dash holes. You can take the 1.5” tweeter and wire it in parallel as well
The rear speakers are 6” so those would work in the doors but you I had to cut out the speaker grills as the improved bass was causing some buzzing.
And then the amp is 3533798. There’s a thread or two on how to hook that up but pretty simple if you also pull the wiring harnesses with it.
9472753 Rh front.
3533967 Lh front
lrock
- Year and Model: 2001 v70 xc
- Has thanked: 9 times
- Been thanked: 37 times
i used monster fm transmitter from wally world no pop, no buzz, bass boost if you're into that sort of thing. you just need to find a good channel that doesn't have a relatively strong signal or close to strong signal and your golden.
i'm also not using it anymore for .. reasons so i'll ship it to anyone that wants it.
- 12 Replies
- 5393 Views
Last post by j-dawg
- 1897 Views
Last post by 1bigklutz
- 890 Views
Last post by CIK7
- 1904 Views
Last post by subzerocarfanatic
- 3396 Views
Last post by SuperHerman
