2008 S80 Power Steering Pump noise
Robranger714
- Year and Model: 2008 S80
I recently replaced the power steering pump and filled/bled it with the proper fluid. It is still making noise. It sounds like the noise is coming from behind the pulley, where a spring loaded pulley (?) is behind it. This thing has 2 alignment pins that the power steering pulley lines up with. What is this thing and why can't I find one online?
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
The reservoir has a built in filter in the bottom.
Did you replace the reservoir?
https://www.freel2.com/forum/topic31501.html
Volvo Engine Water Pump Coupling - Genuine Volvo 31219096
Good luck
Paul
Good luck
Paul
- 9 Replies
- 5784 Views
Last post by Turbo_Boss
- 5502 Views
Last post by chitownV
- 1112 Views
Last post by MoVolvos
- 4062 Views
Last post by mlotek511
- 12 Replies
- 4468 Views
Last post by lntravler
