Flare nut size for brake lines
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I am replacing all of the brake lines on my 2002 V70 XC. I will also replace the brake fluid during that time. Are there any special tools I would need other than flare wrenches and something to bleed the brakes with? Are the flare wrenches required? I read on this site that an 11mm one is used for an older 850. It seems that the stores near me have all sizes except for 11mm. Is this size needed for my volvo?
2002 v70 X/C 288k miles
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Wonder why you're replacing them? They last forever even in New England.
02V70
Post by 02V70 »
They were cracking and users of MVS said to replace them
viewtopic.php?p=629695
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Yes, use flare nut wrenches. A metric set is worth having and should have all the sizes. They have a different size on each end.
02V70
Post by 02V70 »
Do you know if the 11mm is needed? The wrench set at harbor freight has pretty much everything except for 11mm.
BlackBart
Post by BlackBart »
I don’t, sorry.
BlackBart
Post by BlackBart »
I have this set. The smallest is 9mm/11mm.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
i went cheap, $11 but they're beefy enough not to spread open.
https://www.amazon.com/SEDY-4-Piece-Spa ... merReviews
vtl
Post by vtl »
02V70 wrote: 23 Mar 2024, 20:00 They were cracking and users of MVS said to replace them
That's brake hoses =) Lines are made of stainless steel if I'm not mistaken.
I used just regular wrenches, but flare ones would be easier.
Been thanked: 504 times
Post by cn90 »
Propane torch is useful.
Front hoses are not too difficult
Rear hoses can be a nightmare at both ends (where it is attached to the metal lines and at the caliper itself)...so if you don't have to replace the rear hoses, leave them alone.
