'03 v70 Base cranks, no start, no codes, pump's audible
olpossum
- Year and Model: 03 V70, 99S70
Went out one morning last week, it cranked but didn't start. The pump ran for about a third of a second, like always when you start it. There's no gas in the fuel rail. 270K miles, pretty original, seems to be the PEM, which I'm not finding. And that removable lid behind the driver's seat, I removed it, and there's nothing else there to remove. Replaced the fuel pressure sensor. Anybody know where the PEM is in this car?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
probably has no pem.olpossum wrote: 20 Mar 2024, 12:55 Went out one morning last week, it cranked but didn't start. The pump ran for about a third of a second, like always when you start it. There's no gas in the fuel rail. 270K miles, pretty original, seems to be the PEM, which I'm not finding. And that removable lid behind the driver's seat, I removed it, and there's nothing else there to remove. Replaced the fuel pressure sensor. Anybody know where the PEM is in this car?
- RickHaleParker
- Been thanked: 979 times
Check passenger side of fuel tank near fuel filter.
Active
Past
Past
- jonesg
if the pump primes, the pem is responding.olpossum wrote: 23 Mar 2024, 18:07 Thanks for the reply, I found it, hidden. Got it out, unseen, with the aid of quite a bit of profanity.
reading the fuel pressure at the rail is the test i'd do.
olpossum
The fuel pump runs when you turn the key to position II--the one right before it cranks, anyway. I appreciate you responding, this is a problem for me. It appears the fuel pump relay is on a little board up under the dash near the driver's door. Judging by the length of the bundle of wires running to it, it can be removed for access, do you know how it gets released? Can't even get a phone up in there.
- jonesg
if its part of the cem there are plenty of youtube videos showing removal.olpossum wrote: 07 Apr 2024, 13:16 The fuel pump runs when you turn the key to position II--the one right before it cranks, anyway. I appreciate you responding, this is a problem for me. It appears the fuel pump relay is on a little board up under the dash near the driver's door. Judging by the length of the bundle of wires running to it, it can be removed for access, do you know how it gets released? Can't even get a phone up in there.
- Has thanked: 311 times
- Been thanked: 817 times
Cycle the key four times to position two, instead of just one time. Still no fuel pressure at the rail?
olpossum
Checked the fuel pressure with a gauge, no pressure at the rail. Cycled the key 4X, no fuel, no pressure at the rail. I had replaced the fuel pressure sensor. I just removed the PEM & its components, no corrosion found, no evidence of moisture, ever. The sound of the fuel pump is odd, it revs up and then makes a winding-down sound, every time, rather than the normal holding-pressure type abrupt stop.
- Been thanked: 4068 times
Did you open the PEM? The corrosion damage is on the inside
See here
viewtopic.php?p=556647&hilit=2005+v70+PEM#p556647
See here
- 883 Views
Last post by xHeart
- 14 Replies
- 6492 Views
- 10 Replies
- 3863 Views
Last post by 800artfreed
- 33 Replies
- 5965 Views
Last post by cmbfoto
- 1952 Views
Last post by MoVolvos
