Accessing hose clamps for turbo vacuum hoses
arrrxivvv
Year and Model: 2004 XC70
Has thanked: 16 times
Been thanked: 10 times
Post by arrrxivvv »
I'm trying to replace the vacuum hoses connected to the turbo, but find it difficult to access the hose clamps at the turbo's end:
Is there any tricks to get to those? Special tools, access from below, or just try to work it with some pliers from above?
Are tools like this useful?
https://www.amazon.com/gp/product/B003D ... =UTF8&th=1
04 XC70 206k
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
You need to remove the air intake hose (the one running from filter box to turbo).
Been thanked: 472 times
Post by cn90 »
IIRC, BMW and Volvo clamps are often 7-mm type.
So if you have a 7-mm socket, you sb fine.
arrrxivvv
Post by arrrxivvv »
vtl wrote: 02 Apr 2024, 17:17 You need to remove the air intake hose (the one running from filter box to turbo).
Thanks, that makes sense. I'll try that way.
04 XC70 206k
arrrxivvv
Post by arrrxivvv »
cn90 wrote: 02 Apr 2024, 18:03 IIRC, BMW and Volvo clamps are often 7-mm type.
Thanks. Mine have those green spring clamps though (not sure what they're called), sort of like those:
04 XC70 206k
Post by cn90 »
Oh,
Those are Spring Hose Clamps.
For the bigger hoses etc, it is often 7-mm type.
arrrxivvv
Post by arrrxivvv »
cn90 wrote: 02 Apr 2024, 20:37 Oh,
I agree, most others hoses I've tackled are 7-mm.
04 XC70 206k
vtl
Post by vtl »
May I ask why you're replacing those? Many years ago I replaced them with "performance" silicone hoses, but I'm looking at old hoses I still have and there was nothing wrong with them.
arrrxivvv
Post by arrrxivvv »
One of the hoses is brittle on the other end:
I think the previous owner used a junction to replace only that end, without dealing with the hose clamp on the turbo's end.
04 XC70 206k
vtl
Post by vtl »
Yeah, these ones always crack and can be replaced with silicone hoses, no problem. They are here only for EVAP system vacuum. The TCV hoses felt to me like a bit different kind of hose. More rigid, maybe different rubber compound. If you don't have problem with turbo, don't replace them.
