.ignatz wrote: 06 Apr 2024, 14:45 I just got my dash display back from European Electric and everything is great. Very Happy!
That's excellent. I know David gives his best effort and most of it is just routine however. I took a drive Thursday for the first time and found the everything does light up but for some reason the Trip Odometer settings T1 & T2 will default to the mileage when the damage to the board occurred. The clock will also reset to ---- after shut off. In the message board all the data such fuel til empty and other all default to a number but will reset and work till it's restarted.
Not sure if it's the trace damage or heat but David spent a lot of time working on it. Super glad yours worked out. For now as long as the Odometer is rolling ahead correctly I'm okay with it. Will check in with David sometime to see if he knows how to correct it or if it's possible.
