I think bad check valve! Especially evident from the quick drop to 0 psi when you shut down the car but the other observations too.
Known options:
1 - just live with it, always cycle the key 4 times before starting
2 - replace the fuel pump
3 - install an inline, aftermarket check valve
I have chosen option 1 on our S60. It comes and goes, sometimes it will start up properly for a couple months, then it starts leaking again and have to cycle. Option 3 has been very popular over the years but I don't have experience with it.
06 S60 Intermittent long crank
- Has thanked: 311 times
- Been thanked: 817 times
Bigbishop
- Year and Model: 2003 S60 2.5T
- Has thanked: 2 times
@ dikidera
Yes a leaking injector is possible but I tried out injectors from my 04 C70 T5, the car still had a hard start so at this point, it's most likely the check valve. Thank you for your insight.
Sure that's a good idea - In theory yes but I would expect to see codes (lean, rich, misfire) and poor idling if an injector was leaking so badly.
- Has thanked: 987 times
- Been thanked: 1075 times
The immediate fuel pressure drop to zero indicated the fuel check valve is leaking. It should hold for hours, maybe days.Bigbishop wrote: 05 Apr 2024, 10:16 @erikv11
1. So I just did 4 cycles as you suggested and crancked on the 5th cycle and lo and behold, car started up immediately.
2. I hooked up a gauge at the fuel rail. Did several 0-2 cycles and observed that on first cycle, needle on gauge rose from 0 psi and stopped at about 20 psi. On second cycle went from 0 psi to about 28 psi. On third cycle went to about 33 psi and kept rising following additional cycles. Never did it go from 0 psi to 60 on any individual cycle.
3. When the car did start nicely after 4 cycles, needle was at 60 psi and maintained 60 psi even during revving points.
4. When car was shut down, needle went down from 60 psi to 0 psi literally within a minute.
What do you think?
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
My independent mechanic spoke to me about this issue before. My car intermittently had this issue and he said it was common for the check valve to go bad as stated by volvolugnut. Cycling the key will prime the pump and should let the car start.
2008 S60 2.5T Auto (Sold)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
duty cycle will show if the pump has to run more than 40% to keep it running.yanga001 wrote: 07 Apr 2024, 11:38 My independent mechanic spoke to me about this issue before. My car intermittently had this issue and he said it was common for the check valve to go bad as stated by volvolugnut. Cycling the key will prime the pump and should let the car start.
Yes, see my post at the top of this page (page 2). Same behavior. It's the check valve.yanga001 wrote: 07 Apr 2024, 11:38 My independent mechanic spoke to me about this issue before. My car intermittently had this issue and he said it was common for the check valve to go bad as stated by volvolugnut. Cycling the key will prime the pump and should let the car start.
- 29 Replies
- 7143 Views
Last post by Chuck W
- 1038 Views
Last post by Littlepug4ever
- 35 Replies
- 13607 Views
Last post by goldmandan
- 38 Replies
- 6230 Views
Last post by vtl
- 1812 Views
Last post by jblackburn
