Faint, single "pop" sound when taking off
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
When pulling forward from a dead stop, there is a faint, single "pop" sound that I'm hearing/feeling. Doesn't happen every time, but it's definitely there. Wondering if it could be one of the various motor mounts. Thoughts/suggestions?
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I have it too, I started to think it's either strut mount or worn out subframe bushings.
hu5ker555
Post by hu5ker555 »
Interesting...it also does feel like there is just a little more slop in the front end, for instance when I'm turning into my driveway and going over the curb cut. Otherwise, it rides and feels great.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
A good possibility with some worse than others.
Axle Bolt with Rubber Insulator (Anti-Ping) Front
https://www.ipdusa.com/products/6251/Ax ... o-30670602
hu5ker555
Post by hu5ker555 »
Thanks, but mine is not quite a ping...more of a pop
MoVolvos
Post by MoVolvos »
Or this? One of the more difficult to find noises. Installed these on our 03 S80 T6 with success.
Subframe O-Ring (Addresses sub-frame knocking noise)
https://www.ipdusa.com/products/8283/Su ... vo-8638585
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
hu5ker555 wrote: 09 Apr 2024, 13:33 When pulling forward from a dead stop, there is a faint, single "pop" sound that I'm hearing/feeling. Doesn't happen every time, but it's definitely there. Wondering if it could be one of the various motor mounts. Thoughts/suggestions?
Open the hood, fix eyes on strut mount, bounce car up and down.
Is the rubber on the strut mount broken?
Active
Past
hu5ker555
Post by hu5ker555 »
Looked at both strut mounts...they are good. Actually had them replaced a couple years ago.
dikidera
Post by dikidera »
Sorry actually instead of just strut mounts I was going to say strut bearings. Mine are for sure bad(well the one, I've replaced the other one).
Couple of years ago = couple of years too many now. It's time probably. But also, there is one small rubber pad(also called spring seat) on which the strut spring lays(lies?), if it has disintegrated, which I am sure happens after years, the spring can come into direct metal to metal contact with the strut spring seat.
myname
Year and Model: 2007 XC70
Been thanked: 4 times
Post by myname »
sounds like a sway bar link wearing out
