The baseline is doing the maintenance with good parts. Then verifying they are still good. Using a non-OE PCV has seen more issues than not; OE is Volvo, Land Rover, FoMoCo. I can't remember the last time I heard about issues with someone who changed to a new OE-branded PCV. Unless there was some other cause like rusted and leaking downpipes. This is basic 3.2. The PCV could also make the engine stall out, just like in the P3 2.5t engines that have a diaphragm PCV. The difference between the P3 2.5t/3.0 T6 is that the 3.2 does not have PCV hoses.MoVolvos wrote: 10 Apr 2024, 20:33.EgoziAlon wrote: 10 Apr 2024, 14:22Exactly!chitownV wrote: 10 Apr 2024, 10:18 Just a consideration, if an engine running and maintenance issue is causing the oil accumulation in the catalytic converters and contributing to the P0420/P0430 codes, the engine issues should be fixed first. Since brand new catalytic converters were already installed, if the paint thinner helps clean the cats, this problem will return without fixing the engine issues.
We always start with the known (high-mileage) maintenance first so that new catalytic converters don’t get contaminated. Doing the paint thinner also won’t solve an oil consumption issue, or white accumulation on the spark plugs, or oil burning smell in the engine bay.![]()
But the problem is that i don't have a Clue what is the problem.
Maybe it is the rings... And then i don't have anything to do besides exchanging the engine
Exactly!, the problem is that you don't have a Clue what is the problem. You've got to establish a baseline and then test! Going all over the place looking for things unknown without a potential remedy or just replacing parts can get expensive, so is not the way to start.
Changing parts and hoping the code goes away is not diagnostics. Start with the known and it if improves or is gone you're good but if it comes back then you go into the unknowns. Regardless, unless you establish a baseline of no codes you won't know whether anything you do had an effect. Have to clean and clear before doing other things assuming there is root cause or a combination of causes affecting the CAT.
Known:
* CAT was changed and code came back slower.
* Plugs are starting to foul again.
* Problem improved with 0W40.
First:
* Clean CAT and if code goes away you know it can go away.
* Change oil to 15W40 and see how long before code returns or doesn't return. If the length between code is extended you know it's an oil issue as the or one of the issues.
* At this point you can start to poke around for the unknown and see if you can find something else potentially contributing to the problem.
* Regardless, you have to bring the CAT back to the baseline or else it's wait and see after you decide you want to pursue the unknown(s) and replace parts as a way of diagnosis.
I would NOT recommend 15W-40 for the 3.2. Let me repeat, don't use 15W-40 in the 3.2. This isn't an old white block or a turbo engine. That will NOT solve carbon build up blocking piston drain back holes. This does NOT address the P0420/P0430 issue.
There are 5W-40 oils that can keep their 40 hot viscosity from getting too thin yet will start up with better flow than a 15W when cold, when oil is the thickest. 15W-40 is truly old thinking. There is a difference between excess oil on the cylinder walls not being able to drain out when scraped off with the piston rings, compared to trying to seal the piston rings. Part of the piston rings are the oil control rings. This is what's being referenced about the piston rings and getting them (and the piston drain back holes) clogged with carbon. It's not just a Volvo issue as most other makes have engines with similar issues. This is one reason not to use a 15W oil in the 3.2 engine.
Have you seen the differences in the clearance of the oil control rings and oil drain holes in the video you linked from my Oil Burning & P0420/P0430 thread?
