General V70 XC70 years /5cyl.
Mark31
Year and Model: None
Post by Mark31 »
Hi again everyone, I've still been researching the Volvos.
They seem to be, as everyone says here a diamond or a Dud. Where I'm going with this is I saw an interesting YouTube video where someone took a 5 cylinder with 200+ miles on it and tore it down just to see what it looked like. And the interesting thing that I noticed when they pulled the head was how the engine got dirtier from one side to the other. Almost like the last 2 cylinders were hot and not getting enough oil or cooling from the cooling system. They were quite carbonized and coked up. Is this a common thing with that engine or is that an anomaly. I understand that it has 200+ on the motor. I still think these are cool cars and want one. I just research the snot out of stuff to get a full understanding of it.
Thanks , Mark
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Please provide the video link.
Has thanked: 2200 times
Been thanked: 1852 times
I think you may be over thinking this. I have seen quite a few P2 Volvos, especially XC70's with over 500000km on them (over 300k miles).
The transmissions or Haldex AWD are more likely to fail. The bigger issue is like any car the maintenance that has or has not been done on the car.
Been thanked: 4065 times
In the FingerLakes you have Brumsted in Ithaca who knows all there is to be known about these cars.
The RN white block used in the 1992-2007 Volvos is a fine engine when maintained.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Mark31 wrote: 13 Apr 2024, 13:43 I just research the snot out of stuff to get a full understanding of it.
Thanks , Mark
most videos are repair instruction , maybe because they're worth fixing.?
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I think the video OP is referencing is
or
2002 v70 X/C 288k miles
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Yes, oil flow lowers from cylinder 1 to 5, oil temp raises from 1 to 5. That's expected, because oil pump is on the crank pulley side. Both engines I took apart had the same cooked oil gradient. About 220k miles both.
5 cylinder turbo runs super hot. Engine compartment is cramped, ventilation is bad. 10k OCI and unregulated oil quality also does add to the problem.
