p/s pressure line NLA
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Shoot! 850 high pressure line 9191271 seems to be NLA globally. What options do we have?
a) Aftermarket part
b) try to find someone to press a new hydraulic hose onto the hardlines
c) try to mount a hardline instead of the hise, but if I remeber correctly the flaring has never worked for anyone.
What do youbthink, fellow Volvonerds?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Can you find a used but good pressure line?
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
That should not be a problem since there are plenty construction hydraulic machines services who can replace and press in a new hose on old connections/hard lines.
Also if needed...they can make and replace old hardlines.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1502 times
Been thanked: 3817 times
Save the end connection and swage in NiCopp to fit. They were available about a year ago as I did one on Grunhilde
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
If you need the entire line,
aftermarket is certainly out there.
You can start with eBay as a baseline.
Clemens
Post by Clemens »
abscate wrote: 22 Apr 2024, 13:53 Save the end connection and swage in NiCopp to fit. They were available about a year ago as I did one on Grunhilde
I knew someone I know stole the last one ...
Volvo says NLA, FCP euro, Skandix, Volvo classic (gpc.se) as well.
At least I got the last wagon driprail for a barless roof :D
Summer: 1996 855 R
Donor: 1995 854 10V
Clemens
Post by Clemens »
volvolugnut wrote: 22 Apr 2024, 08:08 Can you find a used but good pressure line?
I have one in my parts car, but after sitting for 6 years, I doubt they'd hold up for a long time.
As for now, I'll keep the slowly dripping line in there, it just doesn't look like fun.
Summer: 1996 855 R
Donor: 1995 854 10V
