2020 V60CC - 36K Tune up
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Is this rim repairable, and then safe to drive?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
xHeart wrote: 25 Jan 2024, 10:02 ….there is no dipstick to check the fluid level.
This
Makes
Me
Crazy
I guess you teach yourself to live with it. To me it’s not visual and intuitive and direct.
A very unmechanical friend blew up his BMW 3-series because he didn’t understand the oil level system and blindly charged on.
BlackBart
Post by BlackBart »
xHeart wrote: 22 Apr 2024, 14:19 Is this rim repairable, and then safe to drive?
Something bad has happened to that wheel. The bead will hold air for now, but note the crack is traveling down from the lip into the bead.
Is this aluminum? There are wheel shops that can restore alum wheels to new. No idea the cost compared to finding a good used one.
xHeart
Post by xHeart »
BlackBart wrote: 22 Apr 2024, 22:01 Something bad has happened to that wheel. The bead will hold air for now, but note the crack is traveling down from the lip into the bead.
Found a replacement over Ebay; but then got the crack welded. The weld specialist says, aluminum wheel repairs and lasts forever. It won't crack at the same spot again.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
xHeart wrote: 15 May 2024, 08:48
Did you go to a wheel specialist or welder?
xHeart
Post by xHeart »
MoVolvos wrote: 15 May 2024, 09:07
Chicago Wheel Service in Elk Grove https://www.chicagowheelandtire.com
MoVolvos
Post by MoVolvos »
xHeart wrote: 15 May 2024, 09:32
Did you require some straightening or just welding? If you don't mind sharing the cost so we all can get an idea in case we need to find a local shop. Thanks.
xHeart
Post by xHeart »
MoVolvos wrote: 15 May 2024, 09:41
The quote was $140, it included removing wheel from the car (this-that-this-that) and then putting it back on after the repair. I walked in with just the rim and got it back the next day for less.
xiaofei204716
Year and Model: XC90
Post by xiaofei204716 »
Volvo, Lynk & Co, Polestar
VIDA is not required, if you want to direct or CEM PIN, you can contact me.
[email protected]
Five minutes to tell you the password, support VDASH/ORBIT/P3 TOOL/DSA
xHeart
Post by xHeart »
matthew1 wrote: 08 Oct 2023, 09:31 Here you go, this has fluids... but stubbornly doesn't address for instance auto transmission fluid replacement. It only, moronically, says "Automatic transmission fluid level, check/adjust". We all remember the P2 fiasco with "lifetime" fluid.
Maintenance_Volvo_Wty_Manual_2020.pdf
One year since Matthew's ^ post. Our 2020 V60CC will be off the warranty soon.
Now preparing for the 50K tune up - just oil and filters. The fluid refresh is coming in stages between 50 - 60K -- mileage when the spark plugs are due.
Fall weather is here.
