I'm replacing the oil cooler lines right now. I have everything out and the only part missing for putting it back together is the recangular thermostat o ring. The old one isn't torn, but it is hardening up a bit.
Since the way to put everything back together favors using some RTV to "glue" the o-Ring into its place during assembly I was wondering if I could use a bit more RTV as a second seal layer for the hardenibg O-Ring. Or should I wait till Monday till the ORing arrives at my dealer?
I don't need to drive the car rightaway, but I want to finish the job and have one Volvo off the jackstand.
Opinions, please!
oil thermostat o ring and RTV
- Has thanked: 987 times
- Been thanked: 1075 times
I am not a fan of RTV. It can cause corrosion from the acetic acid and the crumbly bits that get loose work their way to other areas and cause problems in valves.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I'd wait for the new O-ring. And a little grease on it will keep it in place during installation.
1999 V70 GLT
1999 V70 GLT
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I know just how you feel. But for that amount of time and work, I'd wait for the new one.Clemens wrote: 24 Apr 2024, 06:42 I don't need to drive the car rightaway, but I want to finish the job and have one Volvo off the jackstand.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
This makes +4, wait for the Volvo part. There isn't a lot of pressure on the system at that point, but even a little seepage there can make a real mess.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
4 vs. 1. That's not fair.
So I will be forced to another long haul in my Transit camper van on the weekend.
You are right, it's not worth the risk.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 11 Replies
- 18939 Views
Last post by Gtin
- 1159 Views
Last post by volvodork
- 1247 Views
Last post by Clockboy
- 619 Views
- 902 Views
Last post by mouseskowitz
