98 S70 front hood latch
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
What is the deal and fix for the front hood latch? I've been dealing with this for several years. I pull the cable to open and it loosens on the passenger side but never the drivers side. I get out and tug up on the hood, pull it again and it opens. -- thanks
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
The hood release cable pulls on the drivers side first, and from that latch to the passengers side. Easy/maybe fix; spray lube inside both latch mechanisms. Then coat the U shaped catch piece's on the hood liberally with heavy grease. I do this as one of those general maintenance things. If that doesn't work, then I'd imagine there is an adjustment you can make at the drivers side latch.
1999 V70 GLT
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
it's weird that the passenger side pops, but the driver doesn't because the driver unlocks the passenger side after being actuated.
Maybe you have the rubber bump stop too high, or - as Sveedy suggests - clean and relube it.
1996 855 R,
2010 V70 D5,
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
+1 on checking the rubber bumper elevation.
IIRC, those latches are also height adjustable.
jmitch296
Year and Model: 1998 V70
Post by jmitch296 »
I have struggled with this too. Even after adjusting the latches and with plenty of lube, mine would still only pop one side. If you gently set the hood down and watch as the u shaped catches on the top settle into the latches on the body, if one catch is hitting the side of the latch, take a small hammer and bend the catch it so that it goes straight in to the latch. They bend really easy, so go pretty light on the hammer. With that and some lube, I finally got my adjusted to where it works about 90-95% of the time.
Jason
1998 V70 GLT
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
This is super common. Mine did it too. I ended up putting a furniture pad under the square rubber bump stop on the driver's side to give it a little more height. Worked like a charm and I haven't had to do the pull, lift, pull thing anymore.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
I believe it was bmdubya1198 that mentioned in another post about wedging a piece of cardboard instead of the wood to open the hood.
viewtopic.php?p=636828&hilit=hood+latch+s70#p636828
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I had to do the hammer mod on my passenger side hood loop on my 99. It had been hit in the front so it was way off.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
mar601
Post by mar601 »
Thanks. I had some strong adhesive backed round rubber pads for furniture legs and just put them on those bumpers. Working great.
Has thanked: 1613 times
Been thanked: 4075 times
We keep a piece of Amazon box cardboard in all our P80s to prevent the two pull quickstep. Someday, I’ll do the furniture pad fix
The cardboard gets folded once and wedged between headlight and hood, lightly.
