Replaced thermostat- no heat, perfect engine temp
TisMe
- Year and Model: 2001 & 2004 XC70
- Has thanked: 42 times
- Been thanked: 17 times
Volvo 31293700
Another pro tip, thank you jonesg. That would mean a compromised heater core, opposed to trapped air, yes?jonesg wrote: 29 Apr 2024, 01:10 Grab the heater hoses at the firewall, if they are hot when engine is up to temp its not the thermostat, its the plenum door actuators in the dash.
Wish I took the time to diagnose further today, but I did not. If the "plenum door actuators" of the heater core check out, then I'll have to assume I flagged a maintenance gremlin and messed up some standard maintenance... aka did not burp the system properly.
I look forward to laughing at myself about this once if it turns out to be air in the core
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I share this experience.
Just as a data point, my Black Betty the P2 makes heat RIGHT NOW, even in cold weather. I’ve always been impressed. Our Audi A4 took forever - you’d arrive and it was still blowing cold air on your feet.
- Has thanked: 2857 times
- Been thanked: 1332 times
Yep my P2 and P80 cars were fast to get to heat. My 2017 VW is slow.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
my ford contour took 30 minutes to heat up, the drive to work was 25 minutes.BlackBart wrote: 30 Apr 2024, 09:59 I share this experience.
v70 takes 1/4 mile .
- jonesg
more likely to be the actuator / doors but it could be the core too.TisMe wrote: 29 Apr 2024, 19:13Volvo 31293700
- 11 Replies
- 8989 Views
Last post by oragex
- 18 Replies
- 7226 Views
- 1335 Views
Last post by 516volvo
- 748 Views
Last post by Starlifter
- 14 Replies
- 4018 Views
Last post by erikv11
