Shell Rotella T6 Oil
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
4 quarts of the Shell vs 5 quarts of Mobil One at Wallymart for essentially the same price. Wonder if it's worth the difference.
Has thanked: 312 times
Been thanked: 818 times
Probably not.
With the rebate the T6 is $15 for 4 quarts. You can get 16 quarts (4 gallons) per year at the rebate price; the rebate has been rolled over the last two years. Trying to get us hooked, no doubt.
rguzz
Post by rguzz »
That (as you pointed out earlier) is tough to beat.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
They sell it on Amazon for just under $20 (free shipping, but you pay tax).
I can get 5 quarts of Mobil-1 for $22...free shipping too and pay tax but it gets here like in 2 days!
Btw, our cars take approx. 6 quarts.
This is what I used- also never had any oil related issues with this oil!
https://www.amazon.com/Mobil-120770-Mile ... ds=mobil+1
williamj
Year and Model: 2003 XC90, 1999 V70
Post by williamj »
I was in Advance Auto today and saw the 0W-40 T6 for the first time. I asked the guy if they had just come out with it and his response killed me, "no, we have had it for a long time it was just in the back". I would have been using it all along had I known they made it...
EgoziAlon
Year and Model: Xc90 2012
Post by EgoziAlon »
mtd240 wrote: 18 Aug 2014, 12:47 It's amazing oil (great specs), and cheap ($21/gal at Walmart). It is rated for gasoline engines. Link to some more information.
Search on "bobistheoilguy.com". They have a lot of good things to say about it. I run it in my '90 240, and use German Castrol in the V70.
I know i am reviving an old thread but i would like to ear how is your rotella oil experience with 3.2 engine after years of use
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Stay away from 0w-40. I'm running 10W-60 right now. The engine purrs, and there is less oil starvation on track days.
1996 855 R,
2010 V70 D5,
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
EgoziAlon wrote: 27 Apr 2024, 13:55
Motor oil is a chemical witches brew, not just oil. Most petrochemical industry scientists advise against using diesel balanced oil in a gasoline engine. The additive packages have different specific levels of zinc and phosphorus, which may preclude Rotella from being certified for use in gasoline engines. All of the chemicals in motor oil in the States had their concentration levels changed by regulation a few years ago. Things may be different elsewhere in the world.
In my part of the country full synthetic gasoline rated motor oil is less expensive than diesel engine oil.
Here is an older thread over on Bobs posted by a Shell petrochemical engineer:
https://bobistheoilguy.com/forums/threa ... ed.273637/
Robert uses Mobil 1 in all his cars, has no mercy on them, and his primary car just turned 500,000 miles.
Rotella T6 5w-40 is currently 1,150 ppm phosphorous (http://www.pqiamerica.com/June%202014/s ... ellat6.htm), higher than the recommended passenger car standard of 800 ppm maximum. The max for diesel oils is 1,250 ppm. Phosphorous is an anti-wear additive for the engine, but a drawback is high phosphorous levels may damage some catalytic converters.
Shell does make a low-phosphorous version of T6, but only in 5w-30, called "Shell Rotella® T6 Multi-Vehicle Full Synthetic" with phosphorous.
I'm still using Rotella T6 5w-40 in all my Volvos. Haven't killed a cat yet but we'll see!
FYI Rotella T6 is still pretty cheap if you buy in quantity and use their rebate program https://rotella.shell.com/en_us/promos- ... S9PMjU2Ny8
MoVolvos
Been thanked: 525 times
Post by MoVolvos »
Started using Rotella T6 15W40 in the 00 S70 SE NA due to the ticking problem from the oil pan O-ring. Engine is smoother but the prior Mobil Delvac Dino 15W40, sold at Costco for many years (no more) worked better, meaning stopped the noise altogether. Have the Rotella T6 15W40 in the 2002 V70 XC at this time. Replaced last week so far so good. Will see if it's too cold for winter this year.
