Glue for exterior body plastics 06 S60
Has thanked: 292 times
Been thanked: 765 times
I need to glue a clip back onto a small exterior trim piece, a straight piece under the driver's side rear door.
Trim piece
Trim piece
Looks like someone has already been in there, but their glue repair finally failed.
Clip with glue splooge
Clip has detached
Clip has detached
The back of the plastic is stamped "PP+EPDM+M10" I suspect it is just polypropylene?
Plastic stamping
Plastic stamping
Any suggestions for an adhesive that will stick?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1850 times
Been thanked: 1712 times
JB weld Plastic (black). Roughen the surfaces and mix the JB weld and stick it. Give it 24hrs to set. It does dry in about an hour but but on the surface. Give it 24hrs for good measure. I use that to rebuild broken P80 dashboard mounts.
enotslim
Year and Model: 2004 XC70
Has thanked: 71 times
Been thanked: 16 times
Post by enotslim »
I intend to try plastic welding for such repairs. Given the variety of materials now available it seems there will be something compatible with most common "legacy" plastic. With practice welding seems more likely to be successful and stable long term. Joins that are hidden from view, as in this case, can dispense with some aesthetics.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
PP should indeed be Polypropylene. With addition of EPDM and M10.
See this link for EPDM adhesive:
https://www.permabond.com/resource-cent ... -adhesive/
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Plastic welder on Amazon. Get another donor piece to melt, with the same plastic kind letters.
The reason why plastic repairs fail is different thermal contraction rate of different plastics. If the same plastic was used for repair, the repair will hold forever.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Lots of good ideas in these.
