When redoing my timing belt (but only after removing the tensioner) it seemed to me that my timing marks seem odd right now. Could I've been running with the exhaust side 1 tooth of for 7 years without noticing?
How many teeth can the cams benoff w/o causing any damage? Can't be much, I guess.
94 T5 - could my timing belt been off a tooth? Topic is solved
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
- Has thanked: 155 times
- Been thanked: 432 times
2.
3 teeth off is a game over.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
If you detune a T5 by one tooth, you get an R !
- Has thanked: 311 times
- Been thanked: 817 times
Also timing belts can stretch, it may have just been that especially if it appeared to be more like 3/4 of a tooth etc.
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
Mine was also off by a bit, I didn't do the last replacement myself but shop said so. Also finally made the car perform properly, I did have a thread here because it had no power in high rpm
My guess is that there are some people changing them that don't know what they are doing. Doubt it jumped by itself.
850 T5-R '95 auto
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
When I replaced my timing belt two years ago I did so very carefully, and yet after double-checking I found it was one tooth off, so I wasn't careful enough. I corrected it before starting the engine. The engine ran better than with the old belt, which I found slightly, slightly longer than the new one. It became noticeable more fuel efficient as well. So perhaps you caused the 'one tooth off' if you did not really check the timing marks before taking off the old belt.
