2002 XC70 bent valve possibility
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
jimmydean012 wrote: 07 May 2024, 13:18 Alright... I was looking through some previous threads about bent valves and saw where you commented "If the valves hit the pistons even lightly they could be bent and leak air."
Is this using the starter or?
Running engine. Starter can do the damage, too, but that's not guaranteed.
jimmydean012
Year and Model: 2002
Post by jimmydean012 »
I am going to just put it back together and hope it runs... stories from this forum are leading me to consider that it's probably OK.
One more question, how can I pull power to the fuel pump to get it to crank without spraying fuel everywhere? I'm kind of embarrassed to ask but it's not immediately obvious.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I usually pull the fuel pump fuse
jimmydean012
Yes which one is it? It's not clearly marked
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
It is #33 of the fuse panel under the drivers door.
2002 v70 X/C 288k miles
Has thanked: 311 times
Been thanked: 817 times
On the XC70 last time I just unplugged all 5 injectors. However, I think they wouldn't fire again until I reset the codes.
jimmydean012
I just started it, seems to run fine 😎 I found a copper crush washer on the ground afterward, wondering if it fell off the banjo bolt? Does anyone remember if you can see the intake manifold side copper under the banjo normally or is it buried in a recess? 😬 That's going to be fun if I have to get it on there
Been thanked: 4065 times
Check your fuel trims and see if it codes for a vacuum leak. Steel onto aluminum will seal pretty well.
Run it and replace next time.
jimmydean012 wrote: 10 May 2024, 21:43 ... 😎 ...
The shades are iconic, James.
jimmydean012
Does anyone know what these parts are? Leftovers from the job... I think the plastic hose routing thing goes near the pct or somewhere near that gaggle of hoses but I can't remember
