Found in the archives "outer boot large oetiker 91mm 1025 9mm band". Anybody have a source for these or a handful in the garage??
Thanks.
ISO outer cv boot clamp 850t.
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
belmetric.com/clamp-9mm-band-stepless-ear-oetiker-167-stainless/?sku=CV102.5BAND9
It says the sight is down for maintenance at the moment.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
jmartin919
Great. Let us know how they work out. I need to do the same.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Got the Belmetric clamps. They are 102.5mm. My newly arrived GKN boot from Autohausaz, which only cost something like 11 bucks, had a 104mm clamp that was not SS. We found the alignment with the barbs on the 104mm clamps to be a bit better fit. If jmartin919, you want a 102.5 I'll send you one for the postage just pm me. It's likely the 102.5's will fit fine, the GKN is thicker than most replacements, but I went with the 104's for whatever that's worth. Thanks.
jmartin919
Finally got around to installing the 102.5mm band (that rguzz sent) on my 2000 S70 GLT SE. The 102.5mm is too big. By my measurement I need a 91mm. Unfortunately Belmetric doesn't have that size.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
You might be able to get a stainless exhaust wrap securing band and use that instead. Just an idea in case you're stuck otherwise. You basically run it through the joint, fold it over, and secure the securing clamps, then clip off the excess.
2023 Lexus RZ450e -66k
jmartin919
I have a screw clamp on there now and it's working fine. I'll check out those straps. Thanks.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
rguzz
The turbo axle requires a different sized clamp as you likely know. IIRC the 102.5mm was a great fit for the 96t. If the 2000 is NA it will certainly be different, either way there were weird variations in CVJ size along the way. Sorry my clamp didn't work for you!
- 739 Views
Last post by Volvo S80
- 22 Replies
- 4106 Views
Last post by 98v70dad
- 17 Replies
- 11556 Views
- 35 Replies
- 6619 Views
Last post by cn90
- 1662 Views
Last post by Biggertuna
