Running engine. Starter can do the damage, too, but that's not guaranteed.jimmydean012 wrote: 07 May 2024, 13:18 Alright... I was looking through some previous threads about bent valves and saw where you commented "If the valves hit the pistons even lightly they could be bent and leak air."
Is this using the starter or?
2002 XC70 bent valve possibility
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
jimmydean012
- Year and Model: 2002
- Been thanked: 2 times
I am going to just put it back together and hope it runs... stories from this forum are leading me to consider that it's probably OK.
One more question, how can I pull power to the fuel pump to get it to crank without spraying fuel everywhere? I'm kind of embarrassed to ask but it's not immediately obvious.
jimmydean012
Yes which one is it? It's not clearly marked
- Has thanked: 311 times
- Been thanked: 817 times
On the XC70 last time I just unplugged all 5 injectors. However, I think they wouldn't fire again until I reset the codes.
jimmydean012
I just started it, seems to run fine
I found a copper crush washer on the ground afterward, wondering if it fell off the banjo bolt? Does anyone remember if you can see the intake manifold side copper under the banjo normally or is it buried in a recess?
That's going to be fun if I have to get it on there
Check your fuel trims and see if it codes for a vacuum leak. Steel onto aluminum will seal pretty well.
Run it and replace next time.
The shades are iconic, James.
jimmydean012
Does anyone know what these parts are? Leftovers from the job... I think the plastic hose routing thing goes near the pct or somewhere near that gaggle of hoses but I can't remember
- 16 Replies
- 1758 Views
Last post by RickHaleParker
- 558 Views
Last post by krenekj
- 1699 Views
Last post by JDS60R
- 271 Views
- 4400 Views
Last post by 93Regina
