I did replace 1.6l engine camshafts from 1.8l and i regretted it. It moved the power to wrong spot. So yes i agree this information due experience with theseClemens wrote: 10 May 2024, 15:57 Someone on Swedespeed (quite sure it was Swedespeed) did a dyno test and came to the conclusion that the NA cam swap isn't worth the effort because it moves the powerband in the rev range, but the real world gains are negligable. It might feel different after the swap, but the dyno saw no real gain as far as I remember. A good tune, a downpipe or choosing a larger turbo will make a bigger difference. if you want it all, it might be a nice addon, but this shouldn't be high on you shopping list if you're looking for more punch.
