2005 volvo s60 R UEM replaced and thrown away
My uem was replaced and everything works except the key fob buttons? Will I need a new uem and key fobs or just a new key fob and uem update? Or rather just an update and old key fob will work again? I already through away the old mirror and yes the fob worked prior to mirror replacment
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
If everything else works but the locks I'd live with it but we never lock the car in Maine.
You might try shooting yagger an email or is it doodlebug?
https://www.datatransferring.com/volvouem
- jonesg
its above my paygrade but yagger has said in the past ,
"It is very easy.
Every UEM has a original access pincode. When dealer try to download original data from server to your used UEM, they cannot do it successfully, because pincode from server does not compatible to pincode from your used UEM. There are some ways to fix this "issue":
1. You can ask dealer to install new UEM (I mean NOT used but realy NEW brand module) and download original SW and data from server to it. (But here also there are pitfalls.)
2. If you still did not throw away your original UEM and you have DiCE also, you can use our online service for transfer sw and data from your original UEM to your used UEM, or you can mail UEMs to us.
3. If there is not original UEM already and your remote has partnumber 8685150 and you have DiCE, you can mail your remotes for reset service to us, after this procedure we able to program it to your used UEM like new remotes (for us does not matter your pincode). Or you can send us full kit, remotes and UEM, we will do same operation in our lab.
We located in San Jose, CA"
https://www.datatransferring.com/volvo.
- 14 Replies
- 619 Views
- 1338 Views
Last post by FLXC90
- 2455 Views
Last post by Pedey
- 613 Views
Last post by Cees Klumper
- 1040 Views
Last post by thr3shold
