Hello everyone,
I have recently acquired a Volvo 850 T-5 1997. The issue that slightly annoys me ever since then is the driver side’s lock. I didn’t get a remote key fob, so I use the manual key to open. However the key button pops up very weak and I usually need to juggle the fob to the left twice to actually keep the lock as unlocked position. I think the lock mechanism seems to be weak, I haven’t opened the door panel yet so I wondered if any of you all had a similar experience. I couldn’t find one yet.
Driver side door lock issue 1997 850 T-5
juicywheat
- Year and Model: 1997 850 T-5
- Has thanked: 2200 times
The only way to find out the issue for your car is to remove the inner door cover and have a look. There are parts that wear and eventually break in the door actuator. There may also be a loose or worn lever for the door lock mechanism.
The pooping open again is due to the actuator being broken. Often on the passenger side or rears when people try opening the door while it is still unlocking. It breaks a small plastic piece internally.
- 1897 Views
Last post by stefmit
- 1715 Views
- 5839 Views
Last post by volvo240student
- 774 Views
Last post by Vova585
- 12 Replies
- 2040 Views
Last post by dosbricks
