Hello, I have 850 97 T-5. Abs light has been turned on since I got the car and I had a chance to scan OBD. Here are the error codes:
01
ABS Intermittent LR Wheel Sensor Signal
Intermittent Fault, Extrapolation Counter
20
1. Control Module - General Fault
2. Front Right Wheel Sensor Fault In Sensor Circuit
30
Intermittent Rear Left Wheel Sensor - Fault
In Sensor Circuit
40
Intermittent Rear Right Wheel Sensor Fault In Sensor Circuit
I have considered to change the module by myself from the Midwest module. I am wondering if I need to change or remove individual sensor(s) from the wheel, I’d appreciate any suggestions or tips. Thanks again.
ABS error codes- 850 ‘97 T-5
juicywheat
- Year and Model: 1997 850 T-5
- Has thanked: 2200 times
It is 99% the ABS module. Get Matty to send you a rebuilt unit on exchange.
When you get that many errors it may have something else going on but hard to identify when the module is likely the issue.
For test purposes only, try wedging some cardboard between the power leads and the ABS module. What this does is push the internal pins harder onto their seats where they have likely separated from. Clear the faults (take notes of what they are for your own amusement) and then start the car and see if any come back.
- 11 Replies
- 3730 Views
Last post by gcb50
- 1743 Views
Last post by CDoore54
- 1410 Views
Last post by tryingbe
- 979 Views
Last post by nissan
- 10 Replies
- 1953 Views
Last post by Addswing20
