VIDA 2014D_Repack install on Windows 10, any version.
C30D5Peasant
Year and Model: 2007 C30 D5 Auto
Post by C30D5Peasant »
First of all, thank you to all involved !
I'm just trying to get some torque spec's for various things (hopefully in this VIDA thingy).
I'm just running into this issue, which I didn't spot anyone else mention:
My machine is on Win 10, I've run scripts as administrator but this is happening on the 2nd one.
I've also tried it on my Win 10 laptop, exact same issue.
And this is the error from the log file:
System.ApplicationException: Error while running vida.install.dot.net.xml ---> System.ApplicationException: Error while loading file vida.install.dot.net.xml ---> System.ApplicationException: Error while loading task install.doinstall.vida.diag.install.remove.ie.config.file ---> System.ApplicationException: Could not evaluate parameter filename. ---> System.ApplicationException: Could not evaluate parameter or property: ${windows.internetexplorer.path}\${ie.config.filename} ---> System.NullReferenceException: Object reference not set to an instance of an object.
at Framework.Utilities.Registry.ReadLocalMachine(String subkey, String valuename, String defaultvalue)
at Framework.Utilities.Locals.get_InternetExplorerPath()
at alba.core.XMLProperties.GetPropertyValueFromXML(String propertykey)
at alba.core.XMLProperties.ParseToLowest1(String val)
--- End of inner exception stack trace ---
at alba.core.XMLProperties.GetPropertyValue(String propertykey, String enumtable, String enumkey, String& val, Hashtable& tbl)
at alba.core.XMLProperties.GetParameterTable(XmlNode item, String enumtable, String enumkey)
at alba.core.TaskManager.AddSelectedTaskFromXml(XmlNode item, String enumname, String OrderBy, String overrideCriticalAttribute)
at alba.core.TaskManager.LoadSelectedTasks(String filename, String enumname, XmlNode root, Boolean overrideRunAttribute, String overrideCriticalAttribute)
at alba.core.TaskManager.Load(String dependencyfile, String selectedtasks, String task, Hashtable properties, String ParentTaskName, Boolean overrideRunAttribute, String overrideCriticalAttribute)
at alba.core.TaskManager.Load(String dependencyfile, Hashtable properties, String ParentName, Boolean overrideRunAttribute, String overrideCriticalAttribute)
at alba.core.tasks.RunFromXML.Start(String ParentTaskName, Hashtable parameters, Boolean overrideRunAttribute, String overrideCriticalAttribute)
at alba.core.WorkerThread.start()
2023-12-07 10:37:44 [INFO] [install.doinstall.vida] install.doinstall.vida.create.image.update.folder Never started because it's predecessor failed!
2023-12-07 10:37:44 [ERROR] [install.doinstall.vida] [FINISHED] [NOK] [TOTAL TIME: 00:00:31.5532415]
System.ApplicationException: Error while running vida.install.vida.xml ---> System.ApplicationException: install.doinstall.vida failed!
2023-12-07 10:37:45 [INFO] [install.doinstall] install.doinstall.desktop.shortcuts Never started because it's predecessor failed!
2023-12-07 10:37:45 [INFO] [install.doinstall] install.doinstall.config Never started because it's predecessor failed!
2023-12-07 10:37:45 [INFO] [install.doinstall] install.doinstall.autostart.items Never started because it's predecessor failed!
2023-12-07 10:37:45 [INFO] [install.doinstall] install.doinstall.databases Never started because it's predecessor failed!
2023-12-07 10:37:45 [INFO] [install.doinstall] install.doinstall.eswdl Never started because it's predecessor failed!
2023-12-07 10:37:45 [INFO] [install.doinstall] install.doinstall.Add.InternetExplorer.registry.key Never started because it's predecessor failed!
2023-12-07 10:37:45 [INFO] [install.doinstall] install.doinstall.add.accesscontrol.to.install.root Never started because it's predecessor failed!
2023-12-07 10:37:45 [INFO] [install.doinstall] install.doinstall.Add.EnableIEHosting.x64.registry.key Never started because it's predecessor failed!
2023-12-07 10:37:46 [INFO] [install.doinstall] install.doinstall.copy.uninstall Never started because it's predecessor failed!
2023-12-07 10:37:46 [INFO] [install.doinstall] install.doinstall.remove.readonly.attribute Never started because it's predecessor failed!
2023-12-07 10:37:46 [ERROR] [install.doinstall] [FINISHED] [NOK] [TOTAL TIME: 00:01:08.5886059]
System.ApplicationException: Error while running vida.doinstall.xml ---> System.ApplicationException: install.doinstall failed!
2023-12-07 10:37:46 [INFO] [install] [FINISHED] [NOK] [TOTAL TIME 00:01:09.5668367]
2023-12-07 10:37:46 [INFO] [finish.nok.CreateFile] [STARTED]
2023-12-07 10:37:46 [INFO] [finish.nok.CreateFile] [FINISHED] [OK] [TOTAL TIME: 00:00:00.0010010]
Found this very helpful thread here, so going through this first:
https://www.swedespeed.com/threads/volv ... ro.242441/
I couldn't get it working on my PC but somehow...somehow it worked on my laptop, which at the end of the day is exactly what I needed !
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
240gator wrote: 20 Nov 2023, 11:40 If anyone runs into this issue, I re-ran scripts 1-4 and patch. Reboot and DICE selection came back!
That fixes a lot of things.
Active
Past
PedroLuis
Year and Model: V70 T5 2000
Post by PedroLuis »
I everyone.
Many thanks for all the posted questions and answers.
I got all the instalation, but VIDA don't accept any password: ADMIN; Admin; admin; 1,2,3,4,1234; anyone.
Any help please?
Regards
RickHaleParker
PedroLuis wrote: 27 Dec 2023, 09:29 I got all the instalation, but VIDA don't accept any password: ADMIN; Admin; admin; 1,2,3,4,1234; anyone.
Any help please?
Run the 2099 patch again. Use the default install path.
Active
Past
PedroLuis
Post by PedroLuis »
Hi.
I have installed the software, with all steps, but VIDA don't accept any password: ADMIN; Admin; admin; 1,2,3,4,1234; anyone.
Can you help please?
Regards
bhammy187
Year and Model: 2006 XC90 2.5T
Post by bhammy187 »
PedroLuis wrote: 01 Jan 2024, 15:14 Hi.
Regards
You probably need to add the IE Tab extension.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
Windows 10 pro just made MS Edge the default browser. When VIDA starts in Edge I select 'open in IE' but it won't work.
I'm getting this error 'getCommToolSettingsObject(...),DiagnosticAllowed is not a function'.
To fix this error I had to open REGEDIT.
Go to this folder
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MICROSOFT\.NETFramework]
After clicking (DEFAULT) I then changed the DATA from 0 to 1
Ensure the EnableHosting Data is also set to 1
regedit vida fix.PNG (40.52 KiB) Viewed 9645 times
Peppermil
Year and Model: 2014 v40
Post by Peppermil »
Just wanted to stay thankyou @Rikhaleparker. I did not have a clue what I was doing just followed your instructions. Had to install patch 2099 twice and that was that. It was really kind and helpful to Volvo owners. Very grateful and appreciate the time you have put into this and the support you are still giving guys. Thankyou so very much
alevol
Year and Model: 2005 S60
Has thanked: 6 times
Been thanked: 3 times
Post by alevol »
DavisIan22 wrote: 22 Sep 2023, 17:03 I went through the entire installation process including the patch without issue. I am in the IE Browser in edge, and I can input a username. I tried admin, 1, 2, 3, and 4. It accepts it, says please wait, then instantly refreshes the page in a ms or 2 and has me type it in again. I added a short screen capture of what I am dealing with. Any solutions?
I have the same situation. Vida is installed and running, but when trying to log in, I am stuck at http://localhost/Vida/PreLogin.do page. I put 1, 2,3,4 or admin as a login, it starts loading but then got the same page opened. I have tried it on virtual machina, my laptop. Reinstalled windows (versions 1903 and 22h2) no progress. Could you please tell me how to solve the problem.
Thanks
Update: Patch was the reason
moogletimes
Year and Model: 2004 S40
Post by moogletimes »
Unfortunately, I can't even get past the first part. Specifically SQL setup gets stuck on the same part. "SqlEngineDBStartConfigAction_install_configrc_Cpu32". Or "SqlEngineDBStartConfigAction_install_configrc_Cpu64".
Doesn't get past this no matter what I try. The service "SQL Server (VIDA)" is just stuck in "Starting" status, if I kill it in any way, the setup just unstucks and fails.
Only Windows 7 doesn't get stuck at this part for me, which is what I'm gonna have to live with. Got it working on Windows 7 Pro x64 SP1 with IE10, albeit with some security alterations in the IE settings so that it wouldn't give me a blank screen on Vida localhost.
Tried it on fresh installs of Windows 10 22H2 stock and debloated(with custom unattend debloater file), Windows 10 20H2 stock and debloated, and Windows 11 23H2, stock and debloated. All of 'em got stuck at this part. Haven't tried yet on Windows 8 or 8.1.
Might try 8.1 later but I've already wasted the whole day on this and need to sleep hahah
Gonna skip trying it on win8 as I just hate it anyway and would rather stay on win7. Am thankful and happy that I got it working at all, but I would very much like to have it working on 10 or 11 because many other apps don't like 7 anymore.
