The green wire to starter is not hot with key turned
The starter runs if I run a jumper from battery to starter - green wire
I cleaned the switch on the ( auto) shifter , it’s making contact ok
Schematic shows a start inhibitor switch , is that the same switch? It might be referred to as a neutral park switch or similar I could not detect a hot wire there despite the position of shifter
I think I need to verify if pink is hot when key turned to crank , I’ve got a spare ignition switch if it’s bad since I took a whole car apart for spares
maybe I need to cut into the harness for access to check , I think it’s a pink wire - for cranking
Schematic shows a test point for cranking starter motor , is it on drivers side in engine bay near firewall , I wasn’t sure what it looks like or if I should feed it 12 V or what
A “starter relay” is mentioned but I’m unable to find such a relay and the diagrams of relay locations on Mathiew’s relay site don’t seem to show such a relay
Can anyone verify if there is a relay involved in the starter motor crank circuit ?
Does the wire from shifter switch run directly to starter motor To feed it hot when key is turned and shifter in park or neutral ?
i Think it’s likely a bad key switch, do I need to change the key and ignition complete assembly or can I just change the switch itself ?
I know there are a couple of bolts there that I’ll need to cut (screwdriver) slots in with a dremil to remove the key switch as an assembly
. any other tips or things to look for ?
I’ll try to verify if I have hot at key switch pink ( I think it’s the pink )
, if not I’m thinking it’s a bad key switch . Maybe I can spray in some cleaners ? Deoxit ? I’m thinking might be best to just swap key switches, if I can use the same key it’s nicer so it fits the doors.
I have too many Volvo keys to carry already because I’m addicted to them
Of course stuck and frustrated without my car but I think I’m basically on the right path , it’s just hard to follow the wires , physically
Thanks all !
Phil
