How best to drain the fuel tank on my 99 S70?
ThaddeusTheBold
Year and Model: 1999 S70 T5
Been thanked: 10 times
Post by ThaddeusTheBold »
Hi,
I have (by the gauge) about 1/4 tank in my S70. I'm about to remove everything from the car to make way for my electric conversion, including the gas tank.
I dropped a siphon line in there with one of the rubber squeeze balls, as far as it would go down before hitting some obstruction; pumped and pumped, but only got air. When I pulled the hose ouot, the outside wasn't damp with gas.
So what's the deal? Is there an obstruction at the end of the fill tube that Volvo put there to prevent fuel theft or something, or is the level just lower than I am thinking? What is the best way to drain this thing before I remove it? I really don't want gasoline going everywhere.
Thank you.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
How about pull a fuel line and jumper the fuel pump relay?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
ThaddeusTheBold
Good idea
Been thanked: 4071 times
It’s about 15 minutes to pump about a couple gallons from the front fuel line
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Unless someone else can think of a reason, I don't see how gas would go everywhere if dropping the tank, as is. Connections are usually all at the top of the tank.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
BlackBart
Has thanked: 967 times
Been thanked: 922 times
Post by BlackBart »
That is true. I'd say it's a matter of weight to lower it. Is a quarter tank that heavy?
Or stick a match in there - it'll be gone in no time.
Full tank about 100 lbs/ 50 kg. Just enough to be annoying. 1/4 tank easy
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Any more than a couple gallons will slosh around and make you curse.
BlackBart
Post by BlackBart »
Agreed. I would also do this work OUTSIDE.
