Vida CEM swapping
Alliottom59
Year and Model: 2007 S40
Has thanked: 2 times
Post by Alliottom59 »
Hello
Volvo S40 2008 CEM P1
I wanted to redo a key on vdash, but I encountered an error.
could you confirm that the pin of the image is correct in the dump?
Thanks
CEM orgine.rar
(319.84 KiB) Downloaded 66 times
al1Volvo
Year and Model: Volvo V50 2011
Has thanked: 3 times
Been thanked: 13 times
Post by al1Volvo »
Yes, it is :
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
gun4a17 wrote: 16 Jun 2024, 05:05 Maneged get flash with dice and "USDT" . Pin at 4e000 484172010746 .
Can some one chek please CEM is H 30786890
I found where is parametr in flash but how can i write back to cem using Dice . i dont have any other programmer . Car prog is on the way.
i tried lukes cemtool but it looks it dont work parameters are in dirent place.
Edit: CEM flash reader says wrong code.
Can i edit manualy cem parametrs and use cemtool to upload bin? does write addres matches or it will brick cem?
Ah perfect are you using an UDS dedicated device? , as I have gone down the UDS rabbit hole but am having some trouble finding a straight forward way of doing so. , I did go down the arduino rabbit hole but that was short lived as most of the repo's don't have any usable example code. , I have been using My DS logic analyzer to read some of the packets but that doesn't primarily support UDS only CAN & CAN FD
Alliottom59
Thank you for your answer
I saved the pin CEM IMMO here :
https://d5t5.com/helpdesk/create/ticket/pin
but the key procedure does not work
However I have the following faults:
- 1er key CEM 6C41
- 2eme key CEM 6C43
what do you think ?
al1Volvo
Post by al1Volvo »
Alliottom59 wrote: 18 Jun 2024, 13:24 Thank you for your answer
- 1er key CEM 6C41
- 2eme key CEM 6C43
what do you think ?
I can be wrong but to me CEM PIN isn't the same as CEM IMMO PIN, they are different, maybe someone else can confirm this ?
Alliottom59
Hello
could you extract the immo pin from the dumps.
I need to reprogram a key
THANKS
CEM orgine.rar
(319.84 KiB) Downloaded 95 times
wormland
Year and Model: 2007 XC90
Has thanked: 13 times
Post by wormland »
Alliottom59 wrote: 19 Jun 2024, 12:29 Hello
THANKS
13 81 21
gun4a17
Year and Model: 07 xc90
Post by gun4a17 »
oscilloscope wrote: 18 Jun 2024, 13:07
Dice...
gun4a17
Post by gun4a17 »
Up i dont want brick cem
Alliottom59
@wormland Thanks
I just tested it doesn't work
here are the photos of the errors
PS: in vdash I cannot delete the bad immo pin code, perhaps a code conflict
