2001 XC70 - dashboard therm reporting drastically low temp?
brian_kearney410
Year and Model:
Post by brian_kearney410 »
My wife's XC70 reported low coolant the other day, so I topped that off, and now the dashboard says it is 33 degrees outside. It's a beautiful, sunny 84 degree day here in Charlotte - any ideas?
Edit - it's 33 F, not in Centigrade.
Thanks
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
brian_kearney410 wrote:My wife's XC70 reported low coolant the other day, so I topped that off, and now the dashboard says it is 33 degrees outside. It's a beautiful, sunny 84 degree day here in Charlotte - any ideas?
Thanks
It got switched to Centigrade mode?
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Strange things seem to happen randomly to these cars...often, which are unrelated. I would think the outside temp. sensor has gone bad. It is located in the right hand (passenger) door mirror housing and connects by way of the PDM (passenger door module) to the combined instrument cluster (what you see on the dash). You might have to go to the dealer to deal with this as a replacement of this unit will require a software download to activate it. Conversely the temp. sensor that does not route to the instrument cluster is in the driver's side door module (DDM) and is routed to the engine's ECU for its functioning. Good luck and let us know how things go.
brian_kearney410
Year and Model:
I have made no changes, and the temp has reported fine over the past four days. Nothing to get too wound up about, I'm guessing.
Thanks for the replies.
MadeInJapan
That's good...let's just hope it was an electrical gremlin and things don't resurface.
