96 850 Voltage regulator 9162683 1 197 311 520
Has thanked: 292 times
Been thanked: 765 times
Re: 96 850 Voltage regulator
Helchemist wrote: 13 Jul 2024, 17:26 Great thread and very timely!
Having issues with power on my 98 V70R and the AutoZone tester revealed alternator as the cause. Primed with a previously ordered part from FCP, I pulled my VR today only to find my old one has the LRC and the new one doesn't. Is it possible to use the small VR on a LRC type? Can you leave it unconnected?
see below post from up the thread
Chuck W wrote: 16 Jan 2019, 07:45 I've replaced the brushes in those before.
Actually just did it when we swapped the motor in the wife's '97 GLT. Swapped alternators a while back, due to a noisy bearing, and installed one of the smaller regulators in it(not having looked at the old one on the car). After the car didn't like that I swapped the old regulator with the very worn (short) brushes in it, and just kept an eye out for a battery light.
I ordered some brushes and "rebuilt" an old regulator I had from an extra alt, and installed that when we swapped motors. I'd found a video online about replacing the brushes, and it was easy enough to do.
Going to replace the brushes in the extra regulator as a spare.
(I'd have to dig up where I got the brushes)
I think this post from Chuck is confirming that no, you can't swap a small VR into an alternator designed to use larger one. But I haven't tried it myself.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
erikv11 wrote: 13 Jul 2024, 20:40
Correct, the VRs do not interchange.
