Chasing evap leaks the system actually finally held pressure but I ly up to 3psi. It was hissing from the fuel pump.
The soap bubbles were coming from the housing. Removal revealed a hairline crack.
Fix is a hot soldering iron to (cross fingers) plastic weld the crack.
Backup fix is is overlay of JB Weld. I melted in some holes on the sides of that section to hopefully retain the JB if it separates from plastic.
Since the only other option is a new pump I'm giving this a try.
Unusual EVAP leak. Fuel pump housing cracked
Andrew Vanis
- Year and Model: 1999
- Been thanked: 11 times
- Has thanked: 2199 times
Is the JB weld you used rated for use with fuel? AS the saying goes, it will either work or not. You have spent some time on this and hopefully you get a successful result.
Andrew Vanis
Re JB+gas... IDK. It's what I had in hand and couldn't get another decent price pump housing in the time I had so rolled the dice.
It works and holds 5psi no issue. Now it's just for how long.
1998 V70 NA (11/97 build date) 230,000mi
That crack is close to the top, so perhaps don't fill the tank all the way? Maybe only fill to 2/3 or 3/4 to try to minimize the JB Weld sitting in gas for prolonged periods.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
There was a recall in the southern US with fuel pumps cracking, I called Volvo Customer Care to open a case and they covered it for me. 2002 S60 with I think 188k miles at the time. I think a fuel rated epoxy would for sure hold temporarily. Ultimate fix is a new fuel pump.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
Andrew Vanis
That is good to know! Is there a recall check I can do online, or is calling the dealer the best way to check?Krons wrote: 14 Jul 2024, 13:25 There was a recall in the southern US with fuel pumps cracking, I called Volvo Customer Care to open a case and they covered it for me. 2002 S60 with I think 188k miles at the time. I think a fuel rated epoxy would for sure hold temporarily. Ultimate fix is a new fuel pump.
The recall may have expired, but worth calling and asking a dealer to look into it and with your Vin# if it was done already.
Wish you luck on this one!
- Krons
Looks like you’d be out of the suspect range.Andrew Vanis wrote: 15 Jul 2024, 08:46That is good to know! Is there a recall check I can do online, or is calling the dealer the best way to check?Krons wrote: 14 Jul 2024, 13:25 There was a recall in the southern US with fuel pumps cracking, I called Volvo Customer Care to open a case and they covered it for me. 2002 S60 with I think 188k miles at the time. I think a fuel rated epoxy would for sure hold temporarily. Ultimate fix is a new fuel pump.
https://static.nhtsa.gov/odi/rcl/2009/R ... 3-8017.pdf
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
Andrew Vanis
Thanks for that. Shows the earliest models covered are 2001
What steps or search terms did you use to find that?
You go to the NTSA site and punch in your VIN.
- 9 Replies
- 6217 Views
Last post by DavidE7
- 1286 Views
Last post by EngineeringBloke
- 1306 Views
Last post by erikv11
- 458 Views
Last post by Gbh
- 1620 Views
