97 s70 2.0T
I am losing coolant for a while. It is random, once the whole expansion tank got emptied after a trip(no light came on the dash while traveling, I parked it and after 2h it was empty).
90% of the time I can't see leaks, last week it overheated while traveling. I went to the mechanic and he had it running for hours, no leaks. Today I changed the radiator since I saw the edges having red color (coolant). It overheated again on the way home. Any tips on how to proceed? Both times it overheated the coolant was boiling.
Coolant loss and overheating.
Oro
- Year and Model: V70 XC, XC70+S60 awd
- Has thanked: 7 times
- Been thanked: 37 times
I would suspect a failing thermostat based on the initial symptoms. Thermostats typically fail open and do not cause overheating (rather, the opposite). You can test this theory with a cheap IR temp gun if you have one (or want an excuse to buy one - they are quite cheap these days, and fun to play with).
I am assuming the mechanic was competent enough to have spotted a head gasket leak, were that the issue. It’s another possibility. The HG leak also causes the reservoir to empty, as the added gas volume blows the coolant out of the system.
- Has thanked: 2200 times
It can depend on the type of thermostat fitted. Several aftermarket ones do not have the little jiggle bypass so if they stick shut they will cause an overheat quickly. I agree with Oro, I would suggest starting with the thermostat.
If that does not fix it, even after fitting a new radiator, I would also check the fan is coming on. If the car is relatively ok on a highway, but overheats in traffic, chances are the fan is not being triggered.
perhss70
- Year and Model: s70 1997
- Has thanked: 6 times
- Been thanked: 3 times
I did a hg leak test. Even with empty tank when I turned the car on the coolant would rise very fast and spill out. The car is at the mechanic atm and I will change the motor with one I had with 100.000ish km
'97 S70 2.0T5
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
There’s a solenoid on the upper rear side of the radiator that controls the fan coming on. My ‘94 overheated long ago and that was the issue.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
The 98 S70 T5 in 2012 had a problem with the needle going to the red and fluid out of the cap. It would do this at times when idling too long. I think it was doing the PCV that I remove the thermostat housing and found no thermostat
. Put one in and the problem went away. Whether stuck open or closed it will create a problem but it may not be yours.
Borrow the tester at Advance or other big box and purchased the fluid to check for HC. You can also just get the kit if you like. I borrowed mine from Advance and they charge you the regular purchase price. I forgot to return it and since it was new never used just decided to keep it. The expansion tank fill hole maybe too large so may have to improvise.
The OP says he did a headgasket (hg) test, but not the result of that. I'm going to assume from his following info the gasket had failed and so assuming in this case it is cheaper to swap a whole lower mileage engine.
- MoVolvos
.scot850 wrote: 19 Jul 2024, 15:43 The OP says he did a headgasket (hg) test, but not the result of that. I'm going to assume from his following info the gasket had failed and so assuming in this case it is cheaper to swap a whole lower mileage engine.
I missed it. Hope the test was done correctly per video. At my suggestion my neighbor purchased one but he kept drawing coolant into it so I went over and redid the test for him.
perhss70
Yeah sorry forgot to clarify. The hg test did show that it failed. The engine has around 350.000km so it was not that unexpected. Imo just changing the hg wasn't worth it so motor swap it is.MoVolvos wrote: 19 Jul 2024, 19:06.scot850 wrote: 19 Jul 2024, 15:43 The OP says he did a headgasket (hg) test, but not the result of that. I'm going to assume from his following info the gasket had failed and so assuming in this case it is cheaper to swap a whole lower mileage engine.
'97 S70 2.0T5
That makes a lot of sense. At that mileage I can see that makes sense. Thanks for clarifying!
Good Luck!
Good Luck!
- 15 Replies
- 3152 Views
Last post by wizechatmgr
- 888 Views
Last post by 93Regina
- 38 Replies
- 12224 Views
Last post by mrbrian200
- 3414 Views
Last post by RickHaleParker
- 2729 Views
