1) this small nipple that the small horizontal vacuum time connects to (the other end is the other end of the intake manifold.
Should it go straight through? I can go in most of the way from the outside. From the inside I can feel an opening there the other end would go.
Can't get of any diameter poker I though there
Blowing compressed air through it it is completely blocked
I can't believe it would be so close to being manufacture straight through and not be open all the way straight through.
2) on this elbow pic, I'm thinking of making the hole bigger to give better suction (thought I read it on here somewhere). Ideas/thoughts? Max size etc?
1998 V70 - PCV stuff out, now what?
Andrew Vanis
- Year and Model: 1999
- Been thanked: 11 times
1998 V70 NA (11/97 build date) 230,000mi
Andrew Vanis
Andrew Vanis wrote: 19 Jul 2024, 20:58 1) this small nipple that the small horizontal vacuum time connects to (the other end is the other end of the intake manifold.
1 - It was just blocked. I took a drill and twisted it between my fingers and kept getting out solidified oil. I figured if I hit plastic I would reconsider the drill approach. eventually if busted through. The hole is full diameter all the way through.
2 - left it OEM size because I forgot about it by the time I had the thing back together. We'll see how it is and if it was good enough OEM shoudl be good enough now....we'll see. Its not too hard to get to and can pull it off without having to pull the manifold.
Andrew Vanis
Now this officially sucks!...the glove!
Success!
Now for a test drive
Something I realized there are many failed glove glove test videos and not too many passing videos.
Before I knew what to look for I thought my glove test was ok since it didn't "blow up like a balloon animal". Since my was a limp/soft glove but full none the less only when seeing it being sucked in that one can see the difference.
Success!
- Has thanked: 2200 times
There is a great deal of satisfaction getting to this point! A lot of work for sure, but chances are it will be is another 10 years for the next one!
Your crank seals and cam seals will thanks you!
You just saved 3-4 hours of work from a popped cam seal….and 15 hours of work from a popped RMS!
Well done that man!
Well done that man!
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
TBD whether that stopped the RMS leak, right?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Andrew Vanis
Fixing the PCV system service does not guarantee a fix on a leaking engine. It may help reduce the flow rate. See my comment on using a seal conditioner on your other post.
- 516 Views
Last post by draser
- 602 Views
Last post by jmartin919
- 9 Replies
- 2664 Views
Last post by jblackburn
- 4447 Views
- 1185 Views
Last post by Davidisnumber1
