My own software stack. A combination of Python scripts, SBLs, WinOLS and HxD Hex Editor. and Raspberry PiRobsS40 wrote: 02 Apr 2024, 20:07 Sorry if this is a dumb question, but what software are you using to interface with the ECU, edit, re-flash?
Ignition advance and dwell time on a Denso ECU
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
RobsS40
- Year and Model: 2006 S40 T5 AWD
- Has thanked: 2 times
- Been thanked: 7 times
Sorry for delay, life including a new job has gotten in the way. I'm very impressed. Any chance you share / sell your software?
I don't know how to get the "tune" in and out of the ECU without opening it and soldering, which I can do, but it seems inelegant.
I've used a few tuning softwares, mostly "TunerPro" for US cars (Chevy) with good results, although there are many "unknown" entries in the parameters, and that worries me. But that's a different thing altogether. Every mess with TunerPro?
dikidera
Also late reply, but I didn't get a notification for the thread. I have not used Tuner Pro I just used the Demo version of the latest Win OLS. With the demo version I cannot save my changed files, but not an issue just more of a hassle.
You have an S40 T5 which I think uses Bosch and not denso, the NA version of S40 uses Denso, but the SH7058 variant which is different than my SH7055.
A 2° increase in ignition advance by itself usually won't account for an 18 hp gain on a naturally aspirated 2.4L engine. On most engines, that kind of change might be worth a few horsepower if the factory tune is conservative and the engine can tolerate the extra timing without knock. I'd be interested to see your logs before and after the change, especially ignition timing, knock correction, AFR, and intake air temperatures. The real question is whether the Denso table values are direct timing values or if there's a scaling factor involved, as that could make the actual advance change quite different from what the map appears to show.Whats the result pls
dikidera
My logs will unfortunately show that the knock sensor is pulling 5-13 degrees of timing. Basically, any ignition advance I added didn't do anything because of some underlying issue(presumably; it could be normal behaviour). And premium fuel DID NOT fix this as I already explained.jos4 wrote: 23 Jun 2026, 15:58 A 2° increase in ignition advance by itself usually won't account for an 18 hp gain on a naturally aspirated 2.4L engine. On most engines, that kind of change might be worth a few horsepower if the factory tune is conservative and the engine can tolerate the extra timing without knock. I'd be interested to see your logs before and after the change, especially ignition timing, knock correction, AFR, and intake air temperatures. The real question is whether the Denso table values are direct timing values or if there's a scaling factor involved, as that could make the actual advance change quite different from what the map appears to show.Whats the result pls
I currently do run a custom tuned map(s).
For future users, either message me or tag me, I do not frequent this board. Also B5244S/S2/SG/SG2 engines use the older Denso ECU, the newer engines, S4, S5 etc use the newer SH7058 and different ECU logic/maps.
I've also discovered for S/S2/SG/SG2 ECUs that there is a special map that highly retards the engine when you mash the pedal. Some kind of protection that IS NOT torque protection for gearbox.
- 1333 Views
Last post by vtl
- 662 Views
Last post by NHVolvoNut
- 3284 Views
Last post by Turbo_Boss
- 14 Replies
- 2373 Views
Last post by mrbrian200
- 1058 Views
