89' 740 no overdrive after bypass
Fahimhr
Year and Model: 1989 740
Post by Fahimhr »
Hello. I have an overdrive issue on my 89' 740 16v. I haven't had overdrive/ 4th gear since I got the car about a month ago, so I installed the overdrive bypass and oddly I only got into overdrive/ 4th gear once and only once, I've tried basically everything, I've adjusted the cable, I loosened the plate and started the car I filled up the tranny with fluid. anyone have any ideas????? Thank you
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Have you checked the plastic linkage connector under the car? They can break and the linkage gets real sloppy.
Overdrive is electric control. Check fuse, switch, bad wiring and connections.
I seem to recall badly worn overdrive parts may not engage.
What is overdrive bypass?
Fahimhr
Post by Fahimhr »
volvolugnut wrote: 21 Jul 2024, 14:32 Have you checked the plastic linkage connector under the car? They can break and the linkage gets real sloppy.
The overdrive bypass is a plate that most people use to eliminate having to buy a new solenoid its an easy install it allows the fluid to pass through the two ports. I installed that. However my shifter linkage is pretty sloppy
IPD offers this part for the shift linkage. Read the reviews for more information.
https://www.ipdusa.com/products/5881/Sh ... 0,969,1268
