960 runs great needs starter fluid
- Has thanked: 987 times
- Been thanked: 1075 times
When was the fuel filter last changed? Fuel pressure should rise immediately when power turned on. What is fuel pressure at fuel rail?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
What does fuel pressure do when engine has been run and switched off? if the fuel pump is not holding or if fuel pressure regulator not holding pressure, then what you lists happens. When it is shut off warm the heat in engine bay will vaporize fuel and empty lines. That will lead to longer pressurization when you crank it over. When it is cold the first few crank revs have longer injector pulses and that will let it purge quickly to get fuel. If the fuel pressure drops much in 20 minutes then it fails Volvo (and others) specs.
How does it run well without spark? How did you measure spark?
Does 960 have single coil or coil over plugs? If single coil, connect old style timing light induction clamp on the coil to distributor wire to see if coil is firing.
If no coil firing, check power and ground at the coil.
- 844 Views
- 12 Replies
- 4344 Views
Last post by JPM
- 9 Replies
- 1428 Views
Last post by lummert
- 11 Replies
- 4105 Views
Last post by straubman
- 2171 Views
Last post by RickHaleParker
