I bought my 2006 XC70 a year ago and it has just crossed the 200K mark. I'd been meaning to try cleaning the throttle body after having mild acceleration issues, and this morning after I stalled while waiting in traffic, I figured the time had come. I'd already picked up a new gasket and a can of cleaner, and I'd been reading a few how-tos posted here and elsewhere for a few days, so I got the car home and went to work very slowly as this was my first time with this particular process.
The TB was pretty dirty but I cleared off all the gunk, slapped on the new gasket and reassembled. I made sure to follow the battery disconnect and reconnect process. After finishing up, I tried starting it up and the idle was up and down, up and down, very rough and much worse than it had been before.
Any ideas on what might be happening? Is it possible cleaning the TB exposed some other issue?
Bad to worse: Cleaned TB, now erratic idle and stalling Topic is solved
- Has thanked: 987 times
- Been thanked: 1075 times
Did you get all of the electrical and vacuum connections properly reconnected? Recheck all of them that you may have touched.
- Has thanked: 2199 times
If you soaked the TB while cleaning it with spray, you may have damaged the sensors. What did you use to clen the TB with? Hopefully if you leave it overnight it may dry out if this is the issue.
Volvolugnut beat me to the other suggestions!
TJWookiee
- Year and Model: 2006 XC70 CC
- Has thanked: 7 times
- Been thanked: 10 times
Rookie mistake. I'd mounted the TB 90 degrees from the proper mounting. Took it down, mounted properly, back in business. Let my stupidity help the next guy. Next time, maybe I'll take photos along the way to see how things were instead of relying on my memory.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
When i cleaned the MAF i remember having to reset some sort of adaptation as the car would instantly stall. Once cleared, it ran a lot better as it relearned the throttle.
2008 S60 2.5T Auto (Sold)
Glad you figured it out! Even better that the car is running better.
- 1445 Views
- 11 Replies
- 2984 Views
Last post by oldironsights
- 14 Replies
- 2523 Views
Last post by Sommerfeldt
- 9 Replies
- 7669 Views
Last post by enriquepr21
- 2802 Views
Last post by dscheste
