NEW TOPIC *** JUNKYARD REQUESTS *****
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
MoVolvos wrote: 08 Apr 2024, 10:03 .
UPDATED:
Should these be a lot cheaper if DIY removed rather than already pulled?
2012 Lever Broke Off @ Red Line & Both Shifter Claws Broken
03~14 XC90 Shifter Assembly
2012 w/o Chrome Lower Edge Trim
07~14 XC90 Lower Passenger Light Assembly
Temp Fixed & Passed Inspection.
Inspection 2002 V70 XC - I think 04 up internal reflectors change?
02~06 V70, V70 XC, XC70 Passenger Light Assembly
Cut opened (red arrow), crack (yellow line), split opened yellow arrow. Tooth brush cleaned cut opened area and inside from the back. Hot glue crack and sides. Scraped and sanded up to 2000 grit then Mother Chrome Polished with DA buffer and sealer.
Update: No longer need assembly or shift lever.
Ordered shifter assembly from eBay and when the seller went to pull it they discovered it was damaged. Promptly provides a refund. Not having driven the 2012 XC90 AWD since purchased from Capital Auto Auction decided not to dump any money into the car till I can figure out if it runs well.
Fabricated / rebuilt the shift lever for under $10 in parts. Initially created just one side attachment and tested in the car. Was able to take the car down the street. The shifter claws had not arrived from FCP so the manual was difficult to use but it works also. Decided to remove and beef it with two side attachments. The FCP Parts Sweden Kit came with two identical springs rather than the two individual types so waiting for them to get back to me.
It's rough as I don't have a vise nor work bench. Just basic tools and hand sanding but found a round drill sanding pad for the second set of attachment to shape quicker
Red Arrow - Hot glue filled the cavity to potentially beef up and so screws won't work loose.
White Arrows - For reference the piece(s) that broke off on each end of the lever.
Yellow Arrows - ABS sheet plastic. 2 new end pieces for each side and spacer from the ABS plastic.
Under $10 for the ABS plastic sheet, screws, washers and split washers.
volvoAgX
Year and Model: 2000, 2006 XC
Has thanked: 15 times
Post by volvoAgX »
2000 V70XC, Wanted: 9209894, 9209895 Rear brake shields "protecting plates"
V70 AWD CH 588640-, V70 XC CH 587442-, V70R AWD CH 587597-, S70 EXC NIVOMAT CH 596636-, S70 NIVOMAT CH 598923-
Rochester NY. Willing to purchase hub assembly if attached to the shields. Need something that is substantially less rusty than what is on the car. These parts were NLA ~10 years ago when I was last shopping for them. Thanks.
06 XC70, 00 V70XC, 15 Accord V6, 24 4Runner
Been thanked: 4068 times
volvoAgX wrote: 02 Jun 2024, 10:46 2000 V70XC, Wanted: 9209894, 9209895 Rear brake shields "protecting plates"
Yeah, those are hard to find. If you want to run this car long term, you might have to think about buying a car from capital as a parts car. Basically , your entire rear suspension is NLA, so line up parts supply now.
5underpressure
Year and Model: 1998 v70
Has thanked: 11 times
Been thanked: 13 times
Post by 5underpressure »
I need a rear view mirror, tan / beige. 98 v70
I’m in Vt little to nothing past ten years in yards here.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
5underpressure wrote: 03 Jun 2024, 10:08 I need a rear view mirror, tan / beige. 98 v70
The rear view mirrors in these should all be gray, I believe.
5underpressure
bmdubya1198 wrote: 03 Jun 2024, 12:56
Cool, wish I had one.
bmdubya1198
5underpressure wrote: 08 Jun 2024, 13:15
I'll double check, I should have one in stock.
5underpressure
Received a mirror from bmdubya1198, promptly shipped, well packed and as described.
bmdubya1198
5underpressure wrote: 12 Jul 2024, 12:27 Received a mirror from bmdubya1198, promptly shipped, well packed and as described.
Happy to be of service!
Has thanked: 311 times
Been thanked: 817 times
Need to replace the wiring to the front right ABS sensor on a 96 850.
So I'm looking for P80 (up to 98) front ABS connector with as much factory wire length as possible, hopefully enough wiring to get back up to the firewall and do a splice up there.
