Throttle kick-down Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Throttle kick-down
Post by Sveedy »
Well Sveedy has picked up a little annoying issue. When cruising at a steady speed, if I lift my foot off of the accelerator pedal, the RPM's stay about the same - as if it was on cruise control. But if I just lightly tap the pedal, the RPM's drop to normal. It behaves exactly like a car with a carburetor where you'd tap the accelerator to kick down the choke. Doesn't do this all of the time, which is making it hard to diagnose.
Throttle cable was replaced awhile back, so it's good. Have cleaned the return spring area of the throttle body, which didn't make any difference.
Could the actual shaft in the throttle body be worn ? TPS ?
1999 V70 GLT
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
I would re-visit that throttle cable,especially if it is aftermarket.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
I agree, maybe something's getting caught or hung up.
Sveedy
Post by Sveedy »
Cable was from FCP. Blue bag. But I'll try fiddling with it. Maybe a little grease on the cable where it comes through the firewall wouldn't hurt.
Thanks !
1999 V70 GLT
Has thanked: 1853 times
Been thanked: 1714 times
Try removing the cable and run the engine holding the throttle on the rotating spring part and see if the engine stays at the same revs or drops off. That might help to identify if the cable or the mechanical part to and including the throttle body is at fault.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
Dirty throttle body maybe?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Sveedy
Post by Sveedy »
So I disconnected the cable from the throttle body and the pedal, and tried to see if it had any hangups. Seemed like the cable itself slid better one way than the other when rotated in the sheath. Put it back together, and it seems to be fixed. I won't really know till I drive it a bit.
Thanks all !
1999 V70 GLT
