2010 xc90 AC engine noise 165K Topic is solved
raquette
Year and Model: 2010 xc90, 2007 xc70
Been thanked: 4 times
Post by raquette »
developed an engine noise. I was thinking this could be an idler bearing but sounds deeper inside the engine. replaced water pump serpentine and idler wheels and tensioner about 20k ago.
any ideas of what is causing this?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Make the video public. It's set to private currently.
Also -> Amazon link
raquette
Post by raquette »
matthew1 wrote: 06 Aug 2024, 09:48 Make the video public. It's set to private currently.
I set it to public. thank you.
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
May be easiest to find source of noise with a mechanic stethoscope.
08 C702.5T (sold)
The non-Swedes:
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
raquette wrote: 06 Aug 2024, 09:42 developed an engine noise. I was thinking this could be an idler bearing but sounds deeper inside the engine. replaced water pump serpentine and idler wheels and tensioner about 20k ago.
Have you cycled the AC compressor to see if the noise changes?
OR?
MoVolvos
Post by MoVolvos »
raquette
Post by raquette »
I've narrowed it down to bad serpentine belt tensioner bearing or noise from the coupler that drives the alternator housing. used a stéthoscope to determine this.
as suggested will remove the serpentine belt to isolate the belt tensioner.
raquette
Post by raquette »
removed the belt tensioner, started the engine with no load on the coupler drive except the alternator and the noise is now gone. the tensioner bearing is not terrible by the spin test.
I saw abscape suggested isolating the tensioner on another forum. Thank you!
napa has the tensioner, pulley and auxiliary idler part so will complete the repair tomorrow.
MoVolvos
Post by MoVolvos »
raquette wrote: 10 Aug 2024, 15:33 removed the belt tensioner, started the engine with no load on the coupler drive except the alternator and the noise is now gone. the tensioner bearing is not terrible by the spin test.
Please take a few photos as my 2012 XC90 is making a little noise in the area also. Haven't own it very long nor driven it much, besides a lack of familiarity with the 3.2 at this time, thanks.
raquette
Post by raquette »
well replaced the tensioner and idler pulley, and the engine noise returned. the stéthoscope does not reveal noise from the water pump or power steering.
stumped at the moment...
