No luck with Tasca, need to order new lock cylinder keyed to VIN, good source?
Allgonquin
Year and Model: XC70 2004
Been thanked: 6 times
Post by Allgonquin »
Hi folks. The ignition switch on my 04 XC70 is failing - and I've only just broken in the car with 285K (miles) on it :-). I've read most related threads on most boards and I'd like to order a new lock cylinder assembly which is keyed to my existing keys. Tasca was a recommended dealer to order this from on some old threads on other boards, but I've tried to reach a human all day yesterday with no luck. FCP is a no go for a dealer item like this. Does anyone have a good source - the closest dealer for me is Annapolis MD, and it is full retail all the way, they definitely do not cater to DIY folks like us. Appreciate any recommendations!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
you could just swap the new blade into the old fob .
Allgonquin
So you are saying to just buy a new lock cylinder assembly, with its own key(s) and replace it, and just swap the blades on my fobs. OK, I guess I get that, but where to get a new lock cylinder assembly for a reasonable price?
Been thanked: 504 times
Post by cn90 »
Have you looked into removing bottom plate?
jonesg
Post by jonesg »
Allgonquin wrote: 13 Aug 2024, 12:29 So you are saying to just buy a new lock cylinder assembly, with its own key(s) and replace it, and just swap the blades on my fobs. OK, I guess I get that, but where to get a new lock cylinder assembly for a reasonable price?
https://www.fcpeuro.com/products/volvo- ... cB#fitment
jonesg
Post by jonesg »
were it me i'd remove the tumblers and make it so any key could turn it, without the fob the car isn't going anywhere.
Allgonquin
The FCP part number does not appear to be the lock cylinder after I dug deeper. It seems to be the "housing" and not the cylinder itself. Regarding the bottom plate, that is my next move, I suppose.
Has thanked: 311 times
Been thanked: 817 times
if you have the part number, you can just give it to fcp. Will likely cost more than tasca.
This dealership in Chicago is great for parts and they answer the phones: https://parts.volvocarslisle.com
Has thanked: 1609 times
Been thanked: 4065 times
Ive done both P80 and P2 and had to use dealer. $500 and drop shipped from VALEO in Germany in 3-5 days
Allgonquin
Hi Erik, just got off the phone with Lisle, thanks for the link. They quoted $344.45 coded to my VIN. I'm going to poke around the lock assembly a bit before I pull the trigger. Maybe I'll get lucky and find a loose widget rattling around in there. Just need to find some quality time in the garage....
