Mixture
1990Volvo740
- Year and Model: 1990 Volvo 740 GL NT
Someone have a diagram for the location of the Air Fuel mixture screw?
- Has thanked: 987 times
- Been thanked: 1075 times
It is the plastic knob in a plastic valve body on the front of the throttle body. If you plan to adjust it, mark it so you can return to the original setting if you find you have made things worse.
You may just have a vacuum leak somewhere.
Paper manuals for 240 (very similar to 740) Volvos used to be common in bookstores.
1990Volvo740
There's nothing there.volvolugnut wrote: 16 Aug 2024, 17:13 It is the plastic knob in a plastic valve body on the front of the throttle body. If you plan to adjust it, mark it so you can return to the original setting if you find you have made things worse.
Yes, no knob there. 740 is different. I will try to find something about A/F adjustment.
Turbobricks forum posting:
https://turbobricks.com/index.php?threa ... ix.375543/
No pictures, but discussion and note that there is no adjustment possible.
- 30 Replies
- 6609 Views
Last post by MrAl
