Can't remember ever doing work on a blower motor in any cars owned. Just in case can the P80 or P2 blower motors be reached with this hack?
Blower Motor Bearing Lubrication Topic is solved
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I did my '03 XC about two years ago after listening to it squeal for about 5 years, still silent today! These motors are too expensive to not do this.
2003 XC 70 (sold)
- MoVolvos
.Blacklab467 wrote: 25 Aug 2024, 20:39 I did my '03 XC about two years ago after listening to it squeal for about 5 years, still silent today! These motors are too expensive to not do this.
Good to know, can it be done in car or does it have to be removed?
- Been thanked: 504 times
The lubrication needs to be done with blower motor out of the car (very easy to remove).
I posted the lub trick in forum, basically using engine oil and let it trickle down the shaft.
The "bearing" is not ball bearings, rather, it is a bushing.
- MoVolvos
.cn90 wrote: 26 Aug 2024, 13:34 The lubrication needs to be done with blower motor out of the car (very easy to remove).
Easy and trick is always welcomed! I guest the motor is low speed so any lubrication will be helpful. Hope I don’t have to tackle one anytime soon.
I last did this lube thingy for my 2005 XC90 in 2017 (it was squealing)...it is now 7 years later, nice and quiet...
Here is the DIY...
viewtopic.php?t=83532
Here is the DIY...
