1997 850 GLT will only start on second try.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
erikv11 wrote: 31 Aug 2024, 12:25 Didn't realize you'd already tested a junkyard pump, I am surprised it didn't fix the problem!
But also Just to clarify I do mean full swap - I'd also test the suspicious fuel pump on the other (well running) car. Check if the problem moves with the fuel pump.
This can be attempted sometime soon.
abscate wrote: 31 Aug 2024, 03:08 Hmmm, that’s worth investigating.
If you give it a shot of ether, 3.14 seconds being the correct blast, will it start first time?
The car is now in Syracuse, so I will have to try this next time it comes home. Of course the new ignition switch arrived a day after we needed it. But there is an issue with the ignition, whether it is the actual tumbler or the portion commonly replaced for electrical faults, there is no firm position for the POS1 slot. You can get it into the POS1 state, but it just turns with no resistance into POS2 with the dash lights and fuel pump priming. Not sure if it is part of the issue, but worth a try. The good thing is that with the attempted fixes so far, it starts very quickly with the second turn of the key, major improvement.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
Has thanked: 2200 times
Been thanked: 1852 times
It could be part of the issue, but is just as likely a worn key or tumbler or both. It may also be the internals of the tumbler are partially seized.
jsrnsis
Post by jsrnsis »
I don't want to jinx anything, but it's been reported to me that changing out the ignition for a brand-new Volvo part has fixed this issue.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
