I just acquired a second '01 V70 T5, to be either put on the road or become a parts car (neither are running ATM). One was built in Sweden in Jan '01 and the other in Belgium in Sept '01. Aside from having significantly different options, the only apparent difference between them is the Belgian having 17" wheels vs the Swede's 16". The VINs differ only in the digit for build factory and the sequence #s (last six digits).
A couple questions, mostly out of curiosity but possibly relevant if I end up swapping components:
- I presume components will be virtually all interchangeable? For example, both trans are model 55-50SN
- Is there a consensus that there is notable difference between cars produced in either plant?
- Is my presumption correct that the sequence numbers will be shared between factories, i.e. no two cars with the same sequence #?
- Is my presumption correct that the difference between wheel size explained simply as different optional configs? The Swedish car has wheels I recognize as OEM Volvo from photos but the Belgian car's wheels I don't recognize and I have yet to take a wheel off to look at the backside.
Any comments appreciated.
Jim
Any differences to be expected between Belgium and Sweden assembled cars?
- Has thanked: 2857 times
- Been thanked: 1332 times
And Flemish!
In all my time reading and writing about Volvos, I don't think I've come across any serious argument that Sweden > Ghent or vice-versa. At least none that I remember. Not anything like the raging debates surrounding other brand's manufacturing in say China vs. US, etc.
- Been thanked: 4068 times
The Belgian factory ran on time as they used Ghent charts.
- Has thanked: 987 times
- Been thanked: 1075 times
My original Volvo, a 1975 245, was built in Belgium. It was a solid car to the end at near 250K miles and 30 years on the road.
- Has thanked: 311 times
- Been thanked: 817 times
Yep, they are fundamentally the same car, though can expect to see some different options.
jrschwit wrote: 04 Sep 2024, 07:57 ...A couple questions, mostly out of curiosity but possibly relevant if I end up swapping components:
yes, completely interchangeable
consensus: no notable difference
correct
yes
- Has thanked: 2203 times
The beer is also way better than Swedish beer!
I would not expect there to be any differences as parts would be sourced from same suppliers due to cost. If they were for the same market they should be the same. The only way there may be differences is if the car was a personal import or from a different market.
If you find out different, I'd love to know!
When I looked for parts for the 1975 245, there seemed to be part variations for brakes, steering and clutch. I sometimes had to look at the parts to get a brand name before ordering replacements. I don't know if these part supply variations were related to the build plant, but I suspect they were.
- 2036 Views
Last post by dmg4
- 245 Views
Last post by levalexi
- 1833 Views
Last post by jimmy57
- 2435 Views
Last post by jmorman
- 1371 Views
Last post by TheYoungSir
